2"x3"frme tubing. What wall thickness you use
Discussion in 'The Hokey Ass Message Board' started by Rob Paul, Dec 14, 2005.
  1. Rob Paul
    Rob Paul
    For those who have built frames using 2x3 tubing what wall thickness do you use? Is the 1/8 " wall tubing too thin? Waiting to buy some and not sure what would be the best.
  2. wyatt
    wyatt
    11 ga. is what i use...
  3. Mule Farmer
    Mule Farmer
    from Holland MI
    1/8 is good and what I used.
    bret
  4. squirrel
    isn't 11 gage about 1/8" thick?
  5. Slag Kustom
    Slag Kustom
    i use 3/16. It has a better look to the bends and 1/8 will flex too much in a long frame
  6. HemiRambler
    HemiRambler
    It REALLY depends on whether or not you plan on additional reinforcement (like a roll cage) or not. The old Pro Gas cars used 2" X 3" X .090" - I used it on my car also, but I put in a decent cage. If you weren't planning on any cage I think I'd go .125" even more if it was a longer wheel base. Just thinking out loud
  7. dragrcr50
    dragrcr50
    just bought 11 ga for my g***er willys ch***is anymore is excess weight on the race track...
  8. squirrel
    It would probably be better to go to 2x4" tube for a longer non-reinforced frame. The extra height does a lot more to reduce flex than using thicker wall tubing.
  9. TheDooWopKid13
    TheDooWopKid13
    we used 1/4 on my brothers rod. but it might of been 2x4
    -TDWK
  10. Belchfire8
    Belchfire8
    I used 2x4 7ga. (3/16") on my frame because of the HEAVY BB ford motor up front....and 'cuz my brother worked at a steel fab shop and could get it new at s**** prices :D
  11. Paul
    Paul
    Editor
    fwiw
    1/8" =.125"
    11 gauge = .1196" (.120)
    five thousandths of an inch difference.
  12. pigpen
    pigpen
    from TX USA
    I also use 2X4, .125 wall thickness for a Model A style frame. Works good, last a long time. :cool:
    pigpen
  13. Chaz
    Chaz
    1/8 wall has always workred for me... remember its pre-boxed, so theres a quarter inch of thickness in the vertical plane.
  14. Harms Way
    Harms Way
    I know some people think it's overkill but I like 3/16, this is my Son Kyle's metal shop project for his senior year. The Frame is 2X4 X 3/16. He won 1st place in the High School M.I.T.E.S. compe***ion in the regon, 2nd place in the state. ( because it was unfinished )
  15. bluebrian
    bluebrian
    from dallas
    used 1/4 inch but there was a caddy motor up front and bags at all four corners. the frame had lots of movement so we used some heavier wall to compensate. Its a 500 cad with 500 ft lbs so im sure it can handle the extra weight. i think that 1/8 is a good strength to wieght ratio though. Look at stock rails or even a late model car. and most cars arent even boxed. I would think 1/8 or 11 or 10 guage would be fine.
  16. leon renaud
    leon renaud
    from N.E. Ct.
    From total performance catalog.their frames are made from1 1/2" x3" .120 wall tube. This is all A and T frames.for anyone wanting to build their own frames I highly recommend buying their ***embly manual its 25.00$ but it gives you blueprints for every single piece you need to build a T roadster and I do mean every piece these are the exact parts used by them in their cars!there are also tons of ***embly tips as well.they also have the Shade Tree Mecanics tv series about building a T roadster on vhs for 15.00$ app.3 hours long 6 episodes this manual should be on every rodders book shelf for reference.
    just mho
  17. 296 V8
    296 V8
    from Nor~Cal
    Keep in mind, if you’re building a relatively light car like a T - A or even a 32, a little extra weight in a street car is a big plus. Makes a big difference in ride quality.
    When I built the frame for my 31 p/u I used 2x3 and 2x4 3/16 wall.
