1952-59 Ford Front End Lower Kit
Discussion in 'Off Topic Hot Rods & Customs' started by Paul2748, Nov 1, 2010.
  1. Paul2748
    Paul2748
    Does any one make a lowering kit consisting of the blocks that go between the lower A-Arm and the spring mounting plate. I know I can make these, but a friend of mine is looking for a ready made kit. Thanks
  2. old lady's mad
    old lady's mad
    im not aware of any , but im sure somebody somewheres dose. its just some 1 inch square tube and some 3/8 grade 8 bolts.
  3. Custom_Crestline
    Custom_Crestline
    Night prowlers does, its an okay kit, not perfect but okay. I'm sporting them anyway, no real complaints other than fighting with them to put them on (not the blocks fault, just the nature of the job).
    www.thenightprowlers.com It may not be listed, so you may need to throw a call their way.
  4. deadendcruizer
    deadendcruizer
    You can get them fom hot rod and custom supply... I think they are in Florida... they are just alluminum blocks and bolts, you have to drill out the rivets on the bottom a arm and sping cup and put the blocks in... Its not to bad, all depends on how high you can get the car to drill and swing a mini sledge to get the rivets out.
    John
  5. Retro Jim
    Retro Jim
    I have seen them on ebay before but really , just go to a metal supply house and get some alum. block and just drill them out then use good grade 8 bolts to mount them . You can also use square tubing or solid steel block but make sure you paint them . There is really no special trick , just be careful and don't do anything stupid like getting up under the car with NO jack stands !
    Hot rodders have been doing it this way for a very long time !
    Of course you can always change the front springs or just cut them to lower the car . You can do any of the above ways to lower the front of your car !
    Jim
  6. freemane1
    freemane1
    I bought a set of the alum blocks on ebay and changed my mind about lowering my 55. I really can't remember what they cost though. Been sitting on a shelf for a year and a half.
  7. freemane1
    freemane1
    Here is the return address from the box my kit came in.
    Valente Auto Service
    21 Cross St.
    West Orange, NJ 07052
    973-752-9261
    I hope this helps.
  8. bigshawn
    bigshawn
    BCS butch'scool stuff home page has all kinds of lowering stuff and the blocks you are looking for
  9. Retro Jim
    Retro Jim
    I think the kits from ebay were around $119 plus shipping but may have been a little cheaper but not by much .
    Jim
  10. parklane
    parklane
    That's a lot of $$$ for about $10. worth of steel and hardware.:eek::eek:
  11. Retro Jim
    Retro Jim
    Yes , but think about how lazy most people are and haven't got the common since to just cut a piece of steel and drill some hole in it either ? That's why you see some of these kits and items people sell on line and you just shake your head and laugh ! That's why I said before to just make it yourself !
    Jim
  12. Chalupa55
    Chalupa55
    from So-Cal
    Hey can someone post a pic of what your talking about I'm confused... LOL. :confused: Not sure if I've seen them before. If I'm thinking about it right it will lower the spring mounting down thus lowering the car. Am I close?
  13. old lady's mad
    old lady's mad
    yes, its a peice of 1 inch square tube or stock. that is bolted in between the springseat and the control arm. cut or drill out the original rivets . put the peice in place and bolt it back with grade 8 bolts. ive seen pics but dont remember where.
  14. Mark T
    Mark T
  15. old lady's mad
    old lady's mad
  16. Retro Jim
    Retro Jim
    They are very easy to make . The hardest part is drilling the holes out if you use a solid piece . A drill press will make it a lot easier to drill . I have seen people use square tubing but that is a lot of pressure on those side wall .
    Nice picture of your front end ! I see you replaced a lot of front end parts or the front end is super clean and painted . I also see someone loves those Cherry Bombs too !
    Jim
  17. Chalupa55
    Chalupa55
    from So-Cal
    Oh yea, I remember now. Yea those should be pretty easy to make. Should be able to get the front end nice and low with a pair of Aerostar springs and that setup pretty cheap.
  18. old lady's mad
    old lady's mad
    jim, thats not my front end. that was on ratrodsrule.com and my car has gl*** packs on it. chalupa,my 55 has has aerostar aprings and torino spindles. its now ridingbarely touching the snubers. im going to trim them and get some tavel room.
  19. Chalupa55
    Chalupa55
    from So-Cal
    Hey Old Lady, I looked at your album, I'm guessing the pic's of the car w/ the black steelies is the current ride height. Looks good. How much do you think the front end has dropped since you changed things?
  20. old lady's mad
    old lady's mad
    probably about 4 inchs. yea black steelies is curent pic. the pic with the mags was after just torino spindles. those are 235/60/14s . the torino spindles droped about 1 1/2"s then the springs droped about another 2 1/2"s . its got a 302 not a y block. 302 lighter, on the steelies are 205/70/15s fronts. 225/75/15s rear. in the rear i have put new springs . havnt decided yet if i want to keep it there or lower a inch or 2
  21. freemane1
    freemane1
    I just found the receipt for my lowering blocks and they cost me 104.90 from Ebay. If anyone wants to try a set of them let me know as I am not lowering my 55. I'll let them go cheap.
  22. Ferrell592
    Ferrell592
  23. 1sicsled
    1sicsled
    from nor cal
    what year did you pull the spindles out of the torrino rumor has it granada will work as well is this true?
  24. freemane1
    freemane1
    If anyone wants this lowering kit I have you can PM me. I'll let them go for $50.00 shipped. They are new in the box with bolts and all.
  25. riskybiz
    riskybiz
    Old lady's mad What year torino did you pull the spindles off of? I have always used Granada/Monarch spindles but they are getting harder to find . fatmans drop spindle are toooo much $$$$.
    Charles
  26. mr. h
    mr. h
    i agree with 53vicky. with the cut aerostar springs I have om almost on the bump stops. if I add the blocks will it just sit on them?
