C10 trucks with airbags
Discussion in 'The Hokey Ass Message Board' started by mugsy, Dec 18, 2005.
  1. mugsy
    mugsy
    from San Diego
    Any '63-'72 C10 owners got airbags on the rear? What typically are you running for PSI in the back while driving?
    -David
  2. mugsy
    mugsy
    from San Diego
    Nobody's runnin' bags on their trucks?
  3. 53sled
    53sled
    from KCMO
  4. Bobski
    Bobski
  5. sawzall
    sawzall
  6. kxmotox247
    kxmotox247
    I've got a 67' Chevy that's bagged. I'm also running dropped spindles in the front and a different rearend with a c-notch. At ride height, I run 85-90 psi in the front and around 45 psi in the rear. Hope that helps.
  7. Joeyd
    Joeyd
    Sweet truck dood, that blue looks awesome!
  8. kxmotox247
    kxmotox247
    Thanks...
    It's going to go up for sale pretty soon. Too many projects and not enough time to even enjoy this one. I've never had a vehicle that has attracted so much attention. I think it's the baby blue and white. You either love it or hate it.
  9. mugsy
    mugsy
    from San Diego
    Ok thanks. Between 40 and 50 psi seems to be a good right height for me. I've still got a couple things to install before I can drive and check it out.
    When fine tuning for optimal ride, is it generally just a few psi one way or the other? Get it to where ride height looks good then +/- a couple psi?
  10. kxmotox247
    kxmotox247
    I think the front rides a little stiff at 85-90. There's not much difference in 5 psi. If I could get it set at the same ride height but with lower pressure, I think the driveablility would be better. 4-way would be nice too.
