Anyone ever skin a car like a aircraft?
Discussion in 'The Hokey Ass Message Board' started by Jet Doc, Dec 18, 2005.
  1. KCsledz
    KCsledz
    Do what fits you! Airplanes sound like they fit. There is nothing wrong with a theme car. Just do it right. There will always be someone who thinks it sucks but thats with any car.
  2. DrJ
    DrJ
    From the text; "Strips of tulipwood of uneven thickness and length were fastened to the veneer with thousands of brass rivets."
    Having seen it at the Blackhawk all I can say is it's magnificent!
    A very good automotive example of the airframe stressed skin was the '60's era Lotus F-1 and Indy cars. On some models they even used flat head rivets countersunk into the surface for less air drag.
  3. 65Luck
    65Luck
    This is another car from the 30s that kinda fits in with this thread. This is the 1932 Duesenberg SJ "Mudd" Coupe, bodied in leather.
  4. wannabewannabe
    wannabewannabe
    Yeah I saw it several years ago. It is magnificent. Maybe I just didn't remember the text...
  5. stealthcruiser
    stealthcruiser
    That one is done in a product called"Stits Poly-Fiber",I believe.
    you shrink it with an iron,(heat,that is),then paint as you like.
    No A-N 470 heads though.
  6. gowjobs
    gowjobs
    Just remember: you asked for it.
  7. Spoon
    Spoon
    I run an aircraft sheetmetal repair shop, and I gotta tell ya.. done right (to FAA specs) that would look cool.
    None of the samples I've seen here have nearly the correct amount of rives or spacing.
    Somebody's gotta do one though.
    Get a FAR part 43.13 1b, 2a manual from the FAA for the correct/ current rivet spacing- pitch laws.
    FYI...
    AN470AD*-*... no dash, no space. Or MS20470(metal type)(diameter)-(legnth).
  8. muffman58
    muffman58
    Beauty! Now that`s art! And a 46 gallon fuel tank!
  9. stealthcruiser
    stealthcruiser
    Thanks Spoon,
    was just referring to the head style.
  10. Deuce Rails
    Deuce Rails
    That's cool. Original suede!
  11. zibo
    zibo
    from dago ca
    i've always loved these cars
  12. Deuce Rails
    Deuce Rails
    Here's Gerald Wingrove's 1:15 scale model of the same car. It's simply amazing, and this picture doesn't do it justice.
    In his book The Compleat Car Modeler, he shows how he, his daughter, and his wife drilled thousands of tiny, tiny holes, and filled them with brass wire.
    He laces his own 1:15 wheels, along with hand fabricating everything on every one of his cars.
    See more at www.geraldwingrove.com.
  13. Spoon
    Spoon
    I know you were bud. I was just clearifying incase some one wanted to order some from an aircraft supply house or the likes. Those guys can get really picky with the part numbers.
  14. stealthcruiser
    stealthcruiser
    Thats for sure.
    have you ever worked with any steel rivets?
    never here.
    all aluminum.
    A's,AD's,D's,DD's,E's and lots of KE'S.
    would like to try some steel ones though,other than
    MONEL.
    they are too damn hard after about a 5/32 dia.
