1952-59 Ford New White walls
Discussion in 'Off Topic Hot Rods & Customs' started by Rodderboy54, Jan 25, 2011.
  1. Rodderboy54
    Rodderboy54
    I got a question because I have never bought NEW white walls before. There is blue stains on the white walls so I asked the seller why....here is his answer....the blue is not a stain it is washable all white wall tires come that way when you buy them new it is used to keep them from turning yellow. The blue washes of easy with hot water or a pressure washer.
    Ok is he right or ********ting me?
    Thanks guys
  2. raceron1120
    raceron1120
    I think that's usual for them to have a protective coating on them when new. I got mine last year, they had that stuff on them and it scrubbed right off. I didn't know it was to prevent yellowing but could be.
  3. the-stig
    the-stig
    I've been running TA radials for about 30 years and they all come with the blue on the raised white letters.
  4. Mark T
    Mark T
    The seller and Raceron are correct its just a protective coating. You may need to use a scrub brush to help loosen it up.
  5. Rodderboy54
    Rodderboy54
    Cool! thanks guys for the info. I was curious cause im not accustomed to having new tires. Ha Ha
  6. Retro Jim
    Retro Jim
    They use that to protect the ww's when they load a truck load of ww tires . That way the ww will stay white till they are mounted and cleaned up . Then you use soapy water and a scrub brush to clean the blue die off . They have been doing that for a very long time . WW tires are very easy to mark up ! They still use the same principal today .
    That is what I was told when I worked in a Esso gas station when I was younger pumping gas .
    Jim
  7. hehe , your ol tart got new shoes! feels great dunnit :D
  8. missysdad1
    missysdad1
    Jim's point is a good one: the whitewall will stain from other tires being stacked on them, so be careful if you take your tires off your car - don't stack them or let one tire touch another. You won't be able to get the stain out.
  9. Rodderboy54
    Rodderboy54
    Thanks for all the info guys, I will have to remember not to stack them. And 4t6ford Yes it does!
