52 Ford 215. The head, starter, water pump, gl*** bowl fuel/vacuum pump have all been replaced and the ignition was upgraded to 12v electronic (under the cap). I also have an offenhauser dual carb intake with freshly rebuilt carbs (one with the gl*** float bowl). The intake and carbs come with the necessary linkage and work great. The engine runs great but the coolant p***ages in the block are clogged. The engine also had the head rebuilt and only has about 100 miles on it since the rebuild. I will sell the engine for a couple bucks more than I paid for the head rebuild (about a grand and I have the receipt) and am willing to let go of the intake, carbs and linkage for 450 OBO. I also still have the original oil bath air cleaner, bell housing and clutch. The only items missing is the exhaust manifold and the ******. This could also make a pretty awesome set up for an old Ford tractor If interested please PM me.
Good luck with the sale. I have a stock exhaust manifold that was blasted and coated with por-15's header coating. If you find a buyer and they need it just let me know. I also have an original intake manifold that was blasted and por-15'd red if you find someone to buy the manifold setup off you and an original gl*** bowl 1904 tha, if I recall correctly, was rebuilt. Not trying to hijak your thread just figured it might help if people worried about finding the parts to complete it. T
