1952-59 Ford How much abuse can a stock rear end handle?
Discussion in 'Off Topic Hot Rods & Customs' started by texas_rat_trap, Jun 22, 2011.
  1. texas_rat_trap
    texas_rat_trap
    Probably a bad ***le but, will the stock rear end handle the SBC? Its a '53 Mainline I6 3spd manual car. I want a 9" outa Maverick...but till I can afford / find one, wanted to know if the stock rear end can handle it. I'm not planning to go to the local drag strip with it, just to fool around in till I can get the 9". Also is the Maverick rear end a good choice -width wise-clearance issues?:confused:
    -Dustin-
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    They are actually pretty tough,in the late 60's I ran several Fords on steep 1/4 mile dirt tracks and never broke one.A lot of guys ran them with stout Y-blocks and they hang in there,running an automatic trans puts a little less strain on a drivetrain and SBC's are not known for making torque as much as they do RPM's unless you put some serious money into them.
  3. texas_rat_trap
    texas_rat_trap
    Thats what I thought. It looked to be a pretty stout rear end. I think I'll stick with it as long as possible or till I blow it up. LOL
    Thanks Again,
    -Dustin-
  4. texas_rat_trap
    texas_rat_trap
    Another question what gear ratio is in this rear end... some one told me it has 390's.
  5. JeffB2
    JeffB2
    from Phoenix,AZ
    6 cyl's with Overdrive were 4:10's without Overdrive like yours were 3:90's either way with an AOD it will cruise just great.
