back then a "normal" truck frame was considered 1/4 ton, is that what you are talking about? If so its the same as a p***enger car frame then its worth more, if its a big frame then it aint worth squat. the truck 1/4 ton frame had some reinforcement plates in the rear kick up of the frame. and thats the only diff ive heard but there may be more. JEFF
***us, The frame number starts with 18- 7????? It also has an x-member just like the car. Thanks for the info. I will post some pictures later tonight
Here ya go. 1932V81818- 001 to 18- 203,1261933V84018- 203,127 to 18- 457,4771934V84018- 457,478 to 18-1,234,3561935V84818-1,234,357 to 18-2,207,1101936V86818-2,207,111 to 18-3,331,8561937V8 - 60hp V8 - 85hp74 7854- 6,602 to 54- 358,334 18-3,331,857 to 18-4,186,4461938V8 - 60hp V8 - 85hp82A 81A54- 358,335 18-4,186,447 to 18-4,661,000 (f)1939Ford V8 - 60hp Ford V8 - 85hp Mercury V8 - 90hp922A 91A 99AContinued from 1938 to 54-506,500 (d) 18-4,661,001 to 18-5,210,700 (e) 99- 001 1940Ford V8 - 60hp Ford V8 - 85hp Mercury V8 - 90hp022A 01A 09A54-0,506,501 to end (g) 18-5,210,701 to 18-5,896,294 99A-101,7011941Ford V8 - 90hp Ford 6 - 90hp Mercury V8 - 95hp11A 1GA 19A18-5,896,295 to 18-6,769,035 1GA-000,001 to 1GA-034,800 99A-257,1011942Ford V8 - 90hp Ford 6 - 90hp Mercury V8 - 100hp21A 2GA 29A18-6,769,036 to 18-6,925,898 1GA-034,801 to 1GA-227,523 99A-466,7011946Ford V8 - 100hp Ford 6 - 90hp Mercury V8 - 100hp69A 6GA 69M99A-650,280 to 99A-1,412,709 1GA-227,524 to 1GA- 326,417 99A-650,280 to 99A-1,412,7091947Ford V8 - 100hp Mercury V8 - 100hp Ford 6 - 90hp (G) Ford 6 - 90hp (H)79A 79M 7GA ---- 799A-1,412,708 to 799A-2,071,117 (i) 799A-1,412,708 to 799A-2,071,117 71GA- 326,418 to 71GA- 414,366 77HA- 0,512 to 77HA- 9,038 (c)1948Ford V8 - 100hp Ford 6 - 90hp Mercury V8 - 100hp89A 8GA 89M899A-2,071,118 to 899A-2,374,315 87HA- 0,536 to 87HA- 073,901 (i) 899A-2,005,028 to 899A-2,374,315 1949Ford V8 - 100hp Ford 6 - 95hp Mercury V8 - 8BA 8HA 9CM 98BA-101 98HA-101 9CM -1011950Ford V8 - 100hp Ford 6 - 95hp Mercury V8 - 0BA 0HA 0CM B0-100,001 (J) H0-100,001 50-100,001M1951Ford V8 - 100hp Ford 6 - 95hp Mercury V8 - 1BA 1HA 1CM B1-100,001 (J) H1-100,001 51-100,001M1952Ford V8 - 110hp Ford 6 - 101hp Mercury V8 - B2 A2 (All)A2-100,001 (J) B2-100,001 52-100,001M1953Ford V8 - 110hp Ford 6 - 101hp Mercury V8 - B3 A3 (All) A3-100,001 (J) B3-100,001 53- 5,001H
Thanks for the numbers. It is in fact a 34 Ford Truck frame The frame will be listed later for sale. Clear can be furnished at a fee.
