1952-59 Ford aluminum radiator in a 54, who has one?
Discussion in 'Off Topic Hot Rods & Customs' started by Baggs, Jul 12, 2011.
  1. Baggs
    Baggs
    i have been talking to jeff about a radiator for my car. i want to see who has installed an aluminum radiator in their 54. pictures would be nice, and info where you got it and how much you paid. Jeff reffered me a seller on ebay that sells them for the mustang application. im almost ready to pull the trigger. just want to see who else has used an early mustang radiator in their ride. thanks guys!
    Jason
  2. Ole don
    Ole don
    They look racy. Often, a stock cooper/br*** radiator works better, if its in good shape.
  3. PaddycakeFTW
    PaddycakeFTW
    I have one. It's a $400 Griffin that fits a 55-57 Chevy, so I had to make a couple of brackets but it wasn't too hard. Although, I bought it before I found this forum so I didn't know Mustang radiators fit, and at that time no one on ebay made radiators that fit our cars directly, either. So I guess what I'm saying is I like the aluminum but you shouldn't do it my way. :D
  4. PaddycakeFTW
    PaddycakeFTW
    Here's an old picture of my setup. I'm currently redoing the radiator mount - now the whole thing sits in line with the core support. I have enough clearance between the radiator and water pump to run the electric fan as a puller rather than a pusher as shown.
  5. Screenz
    Screenz
    from Texas city
  6. Baggs
    Baggs
    @screenz i would love to have that in my car. but i need the ports to be on the p***enger side since i changed water pumps to the short.
    i know that alum radiators look racy, but i would paint the top tank so it would help hide the alum a little bit. i just dont want to worry about cooling issues. its the thing i hate the most with old cars. i hate having to watch the temp gauge more than the road haha!
  7. Screenz
    Screenz
    from Texas city
    I run the same water pump two 90's and exhaust tubbing solve that! I'll take a pic
  8. Baggs
    Baggs
    Damn!!! someone mentioned to me to run a hose across like you probably have. I really didnt want to do that, especially with my old radiator. i have replaced pretty much everything but the pistons when it comes to my motor. so i didnt want to skimp and use an old radiator.
  9. Custom_Crestline
    Custom_Crestline
    I've got a cheap one from summit, and its okay. I'd much rather have a copper br*** one for the look, but it cools pretty well.
  10. Ole don
    Ole don
    If you want quality parts, check with Portell Radiator, in DeSoto MO. He made one for my flathed and it was always cool.
  11. Ferrell592
    Ferrell592
    I will have to look around again, I had information saved on my laptop of a company that makes a 3 & 4 core direct replacement that would handle my 351w. Unfortunetly my laptop recently p***ed away to that great supercenter in the sky and all my info was lost. I'll try to find it again and let you know.
  12. JeffB2
    JeffB2
    from Phoenix,AZ
    The reason I recommended this radiator from Oscars to Baggs is this is a family owned business here in Phoenix that has been here for many years and also one of my old customers when I serviced their uniforms and shop towels before I retired,real nice people.Here is a link to the radiator Baggs ordered the "price is nice" same unit listed in Speedways catalog you can add $100 plus shipping.http://cgi.ebay.com/ebaymotors/1965...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories No epoxy in this unit if you are running the late "long" pump you can get it with a drivers side lower hose inlet.
  13. PaddycakeFTW
    PaddycakeFTW
    Your thread motivated me to go work on the car today. Here's a pic of the updated radiator situation. I'd still rather have gone with something that required less fabrication to work, but I think mine turned out pretty good.
  14. sircampsalot2
    sircampsalot2
    This is the one im going with $110 plus shipping on ebay
  15. Crobrd
    Crobrd
    from Canada
    Wow $110.00, cheapest I was able to find was $345.00
  16. sircampsalot2
    sircampsalot2
    I got it in today and looks ok just a little Small width wise I could have used one about another 2" wide but couldnt seem to find one. I will post pics when I get it mounted today.
  17. Baggs
    Baggs
    that looks nice. do you know the specifics of it? how many row core? are the seams welded or epoxied?
  18. sircampsalot2
    sircampsalot2
    Here's what it said on the adverti*****t:
    • 100% brand new. Never been tried or installed
      [*]Radiator is made of aluminum for maximum cooling efficiency
      [*]OEM Fitment; 25-30% More Cooling
      [*]Specially Welded 3 Row Design to maximize cooling
      [*]Overall size: 19.5" (L) x 22.25" (H) x 4.5" (W)
      [*]Core size: 16.25" (L) x 16.5" (H) x 2.5" (W)
      [*]Inlet/Outlet: 1.5"/1.75"
      [*]Radiator Fans:
      • 12" 12 volt 80w high performance reversible electric cooling fan
      • This fan can be wired to configured in a PUSH or PULL airflow
      • Overall size: 12x12x3 CFM ratio: 1550 / RPM: 2250 on each fan
      • Durable and powerful motor for long life and performance
      • It can easily be installed flush against a radiator
      • Mounting bracket included, exactly shown in the picture
  19. Crobrd
    Crobrd
    from Canada
    could you tell me if you plan on mounting the fan on the grill side or engine side of the rad. Did you change your pump, pulleys and brackets to the Ford racing pump allowing for required additional clearance.
  20. SlmLrd
    SlmLrd
    from DAGO
    I went with champion Radiator for the new 40 coupe. 159 delivered and its good quality. They have a warranty and seem pretty good to deal with.
  21. sircampsalot2
    sircampsalot2
    I mounted the fan on the engine side, I bought the engine from Fordsbyjay he could tell you if its the original water pump or the short type .It has the original pullys, with a short pump I believe. with it installed I still have about 1-1/2" between the fan and the fan pulley. The only thing that is close is the Battery tray is real close to the Alternator I may end up putting the battery in the trunk not sure yet on that.
  22. Crobrd
    Crobrd
    from Canada
    thanks, we turned the battery 90 degrees. Drilled out the spot welds securing the brackets on a Group 29 tray. Welded the brackets on a smaller tray, with the battery facing the opposite direction. Bolted it in, eliminating alternator problem
  23. Baggs
    Baggs
    Just an update, i did order and recieve the radiator that jeff mentioned to me from Oscars. i dont have any photos yet. but i held the radiator up to the original "u" piece that holds the radiator, and i swear this thing is going to fit with not modification. the width is perfect and the holes even line up in the right spot!!!!! when i finally mount it in the car i will take lots of photos. i believe the application i used was for a 67 mustang with a 289
  24. Baggs
    Baggs
    here is ****py photo of the radiator. i will take some more next time im there of the detail how it mounted up. couldnt ask for a better part. question for all of you too. would you paint the top tank black to mask that its aluminum? i cant decide if i want to do that, or leave it. i kind of like it the way it is.
  25. Baggs
    Baggs
    this shows the clearance between the radiatior and the water pump, thanks to Jeff for telling me to buy the shorter pump!!!
  26. JeffB2
    JeffB2
    from Phoenix,AZ
