Torsion bar front end for A-Bone?
Discussion in 'The Hokey Ass Message Board' started by NoCentsRacing, May 11, 2005.
  1. that is a great install, very creative, i like it alot.
  2. Tony
    Tony
    Jeem no problem.
    I was going to call him tomorrow anyway to wish him merry christmas so i'll get the info for ya. I'll probably be out there next week too, so if he's not in tomorrow i'll get it then.
    Tony
  3. Dat Dirty Rat
    Dat Dirty Rat
    Tony- I'm heading out there tomorrow.....I tell him to expect your call!
  4. Devin
    Devin
    from Napa, CA
    Has anyone used VW torsion bars? Super cheap and available.
  5. Tony
    Tony
  6. Old Rod
    Old Rod
    from Brazil, IN
    Lee's old partner is in fact still doing ch***is work in Indiana. I must say he
    does it extremely well also. If you have trouble getting ahold of him PM me.
  7. 29 sedanman
    29 sedanman
    from Indy
    I have contact info for Steve if needed. PM me if needed.
  8. BZNEIL
    BZNEIL
    Here is a track T that I built with my dad. It has cross torsion bars like a sprint car on all four corners. Handles great even with the skinny fronts and wide rears. Has a nailhead, franklin quickchange, and a full tube ch***is.
  9. brandon
    brandon
    your dad's track car is a neat piece....i remember seeing the ch***is out at brandon spades when i was picking up my anglia....a lot of neat stuff on there.....brandon
  10. Bruce Lancaster
    Bruce Lancaster
    Dug out the book (put together in very early sixties) last night. The tub with Packard bars and self-leveler is almost like a fifties version of a modern streetrod...ultimate luxury late model everything, with a '56-58 timeline in mind. No pics of the ch***is, which must be wild.
    The restorod looking '29, owners name something like Nagakawa, used '57 Plymouth bars and arms at all four corners on a homebuilt ch***is. Both cars were totally non mainstrean rods in their day, and VERY well executed by people who probably didn't consider themselves rodders--they just like old cars, but wanted theirs slick and comfy.
  11. Tony
    Tony
    Jeem, sent you a pm with the info.
    Tony
  12. Jeem
    Jeem
    Alliance Vendor
    Got it, THANKS muchacha!!
  13. 32 for me
    32 for me
    from SO. CAL.
    I have been using torsion bars for a long time in motorcycles. They have a spring rate of 800lbs. per inch of travel, memory of up to 22 degress of rotation. According to my calculations this would work in a light car, and can be hidden. What do you think?
    I tried to up load pictures but it says the file is to big and I am not smart enough to figure out how to down size them, have to wait till monday when sombody comes to work that knows how.:confused:
  14. Jeem
    Jeem
    Alliance Vendor
    Gawd yes, I'll be waiting. Gathering as much info as possible, 99% sure how and what I'm going to use but yearn to learn!
    Thanks in advance!
  15. 32 for me
    32 for me
    from SO. CAL.
    Here ya go.
  16. Chuck Fish
    Chuck Fish
    I have a friend that used the front end out of a Volarie. It's in a 56 chevy truck. Might be worth taking a look at that set up.
    Chuck Fish
  17. Mojo
    Mojo
    This is a quick scan from my Feb '55 Popular Science article about the Packard Torsion bar suspension. Click here for the large pic.
    Text that went with the picture: "In new Packard, where a single torsion bar per side replaces both springs, front-end design is roughly the same but lever arm subs***utes for the coil. In rear, another lever presses against stirrup in torque arm running from axle to frame. The two torque arms take over the job of delivering rear-axle thrust, as well as brake torque and drag, to ch***is. Pretzel-shaped bar in left photo above is stabilizer that ties axle against sideways movement. Heavily geared down motor that windws up the ends of the leveling bars is shown in the right photograph above. It runs only when the car loads changes."
  18. scottybaccus
    scottybaccus
  19. xderelict
    xderelict
    Salt Shaker:Return of the Ramblers' Roadster, The Rodder's Journal number 33 shows several views of torsion bar suspension. Very clean, very interesting.
  20. Here's whatI'm using....all vintage sprint car stuff purchased on eBay.
  21. Gnashty1
    Gnashty1
    I snapped some pics of a torsion bar setup installed on the front of a truck (rear was also torsion - no pics) at the Nats North. Don't know how to post 'em (and may not be trainable). Happy to email the pics to any HAMBer who can post them here.
    Truck was built by a sprint racer, ride height adjustable front and rear by turning a bolt. Trucked looked very ratty, but was nicely built. Aluminum buckets, full floor, new frame, etc.
    Anyway - will send pics, or try to post them with help.
    John
  22. Gnashty1
    Gnashty1
    I forgot to mention - the pics show the axle and sock, I mean shock, mounts very well. This was why I snapped them.
  23. has anyone used bug or bus bars?
    also, can torsion bars arms be solid mounted to the axle/ wishbone, or should a link of some sort be used between the bar and its mounting point on the axle/ wishbone?
  24. Most cases require a shackle. The sprint guys allow the torsion arm to ride on top of the front axle but that may not be a good street deal because of wear. Racers replace those arms quite often. I'm using rollers on the axle and under the front arms of my street-legal sprinter to minimize that wear.
  25. atch
    atch
    i've wondered in the past if you built a sprint car type torsion bar set-up and included a "wear bar" between the axle and torsion bar if it would work without wearing out. any opinions? i've got no desire to build such an animal, but have been following this thread out of curiosity.
  26. what are rollers? and do you have any pictures of the set up? - thanks
  27. Here's a quick sketch of a torsion arm/roller setup. To answer atch's question....a wear bar such as U.H.M.W. polyethylene could be fastened to the underside of the arm and then the roller deal could be eliminated.
  28. just to make sure my pea brain gets this...the torsion bars are not secured to the axle at all (is this the same front and rear?) the torsion bar is riding on a effectively a large needle bearing and the wieght of the car provides constant pressure to hold the bar in place. and a wear bar is just a sacrificial piece of material that gives up its life rather than wearing a hole in your axle housing.
  29. Yep....except at the rear ! :)
    At the rear of a sprint car the forward end of the torsion arm (mounted behind and below the axle) has a spherical bearing in it that attaches to the lower side of a birdcage. The birdcage contains a bearing that the open-tube axle turns in. The upper side of the birdcage links to the ch***is via a trailing arm. This forms a watts link that locates the axle (front to rear) and lets the axle move in a nearly vertical plane.
    See sketch.
