Hey Guys n gals , need some input on what size wheels and tyres you are running under your '55-'56 's please . Here's the story , friend of mine has just bought a '56 Vicky , it is on stock rims with narrow whitewall . he wants to get a set of early 5 spokes ( torq thrust or similar ) and is thinking possibly running 15x6 on the front and 15x7 on the rear ( I already told him he wont get any bigger than 7" under the rear ) . The Vicky is stock hieght at present but will get a very mild drop ( prob 2" all round ) and is already fitted with a 9" rear out of a '57 fairlane . Your thoughts and suggestions please .....
I'm running 15x8 with 235/60's all around but I'm running a 98 Blazer rear end, 4 inches narrower than stock.
If he wants to go with 15x7 in the rear and 14x7 in the front, let me know. Shipping would be hell, but I have some Cragars that Im still trying to get rid of!
You should jack the car up like you would do if you have to change a flat and measure the distance between the brake drum and inside of the fender . That way you will know how wide of a tire you can go with so you can change a tire when need be . Then figure out the backspace and go from there . Can't use a tire too wide if you can't get the tire up between the fender and brake drum . Now if you are planing on adding the lower blocks make sure you add the block first , then take the measurements . If you have some friends with wider tires and wheels maybe they will let you try and see if they will fit your Vicky or not . Jim
Thanks for the input so far guys . Dragonknucks you're right shiping could kill the deal . Jim , I follow what you're saying ... problem is this car is still in the USA and as my darling wifeys car here has an 8 inch out of god only knows what under it I can't use it as reference either . ... She reckons I lie about most measurements anyway ...
According to the article in Streetrodder magazine, this one runs 17x7's with 235/45/17's on the front and 17x8 with 245/40/17's on the rear. This with the stock rearend and a bagged suspension. http://image.streetrodderweb.com/f/9466016+w750+st0/0805sr_05_z+1956_ford_fairlane_victoria+.jpg
Hi! FXcomet The rear 18x8 with 4,5" backspace. C5 CHROME WITH BULLET CAP and boltpattern 5x4,5 And 17x7 in front
Rears are 17x8 and 30mm offset I am running 255x 45 tires with no clearence problems. Actually I have nice room to the inner fender. I'm also on a 9" Versalles rear though.
