COE 1962 International Metro car hauler build
Discussion in 'Off Topic Hot Rods & Customs' started by scalhotrod, Jan 2, 2012.
  1. scalhotrod
    scalhotrod
    Hi Folks,
    A few days ago I acquired this thing...
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    It may not be much to look at right now, but it has the specs and capacity for the makings of a pretty decent car hauler. Here's the factory sheets...
    Mine is one of the larger models, an AMC-164 ("A" series truck, "M" for Metro body, C for "cargo" I think). I'm not sure of the weight (tons) designation of the 164 model, but the biggest of these trucks had a max GVWR of 22,000 which even if its a little less should give this thing a pretty decent hauling capacity.
    Here's the best part! The transmissions in these trucks had PTO ports and this one was used. Previous to me buying it, it was used as a garbage truck with a hydraulic compactor on the back. Either way, this thing makes a perfect candidate to have a tilt-back flatbed installed.
    What do you think so far?
  2. LUXLX
    LUXLX
    I actually dig the slant of the nose and the curvature of the gl***, especially on top with the brow. I'd give it alittle more fender and slam it! Looks kool.
  3. Donnda
    Donnda
    What year is it? Does it have the 6 cylinder inline engine? I really think this is a unique and neat unit.
    -Donn-
  4. RMR&C
    RMR&C
    from NW Montana
    There is one of these sitting about 30 miles from me.......always thought it was cool. Looks like a fun build!
  5. fabmancoe
    fabmancoe
    Love the profile of your binder, that is going to be a cool build for sure. Can't wait to see your plan.
  6. Very Cool ! Looks to be in pretty nice condition too. I'll be watching.
  7. v8steel
    v8steel
    Hey scalhotrod;
    I think you've got an excellent idea. I'm currently looking for a decent 50s step van and considering the same thing. I have 2 new stripped motorhome ch***is; a 2007 and a 2011 22,000 GVW models with the V-10 and 5-speed auto trans. Nothing has ever been on these ch***is; 0 miles. Just waiting for the right body donor.
    If you will post a picture looking at your truck straight on from the side, I will take a stab at photoshopping what the end result might look like.
    GREAT IDEA, keep us posted. I'm subscribed.
  8. scalhotrod
    scalhotrod
    Hey Folks,
    Thanks for all of the interest and support!
    LUX, its actually all flat gl***. That's one of the more convenient things about Metros. It already has removable fibergl*** fender flares, widening them wouldn't be too challenging, interesting idea. But I'll probably leave it stock height, its easier to calculate loads and the needs of the tilt-back bed. Don't get me wrong, I'm usually "down in the weeds" low kind of rodder, but I want to make this truck as practical as I can.
    Don, it's registered as a 1962, but that doesn't mean it was built in '62. Just calling it an AM series is probably accurate enough. And yes its got a 240 inch Black Diamond straight six, its rated at 140HP and 223 lbs of torque. One of the neat things about the engine is that it came stock with a Holley single barrel carb.
    On one of the International Harvester dedicated bulletin boards, one of the members developed a turbo-charger kit for these engines and they are for sale for $1,800 complete. How cool would THAT be plus probably just a good idea for overall use and drivability!
    Chevy, mostly its dirty and its been used as a true work truck for a few decades, but its been taken care of and seemingly not abused. There is a little bit of bent metal here and there, but no body rot that I've found and its still pretty solid. There isn't much on it that a good cleaning and the application of lubrication won't fix.
    v8, thanks for the offer, that sounds like a cool plan. Once I get it home I'll post a bunch more pics. I'm trying to find a better deal on its transport than the $800 or so that I'm being quoted by tow companies near the truck.
  9. v8steel
    v8steel
    What do you think? Just taking a stab at it...
    ... and (depending on your state) if you you keep it licensed as an antique and don't have to keep the BRIGHT DOT reflector markings, Voi-la! This looks less modern.
  10. scalhotrod
    scalhotrod
    Wow, very cool V8! Shorten up the cab a bit and it'll be just about right... :)
    And yes, it will be registered as a vintage truck with 1963 commercial plates if I can find a decent set.
  11. RMR&C
    RMR&C
    from NW Montana
    I think your truck will be a cool one of a kind car hauler......I would leave the cab stock length though. That is what makes it so cool!
  12. scalhotrod
    scalhotrod
    Hey folks,
    I found a transporter finally! with any luck it arrives this week, woohoo!
    More pics to come!
    Chris
  13. Like Tom Petty said,"The waiting is the hardest part"
  14. RMR&C
    RMR&C
    from NW Montana
    This old Metro sits about 30 miles from me.....has been there as long as I can remember.
    Last time I drove by the grille cover was ripped off. I think the s****pers/crackheads stole the radiator out of it. No one lives there where it sits....
  15. scalhotrod
    scalhotrod
    It's home!! I'm about to go visit it where I have it stored. As soon as the weather is nicer, copious pics to follow!!
