1952-59 Ford gearheads power steering in 1956
Discussion in 'Off Topic Hot Rods & Customs' started by lasbde, Feb 13, 2012.
  1. lasbde
    lasbde
    Has anyone used Gearheads Cruiser Products power steering gearbox set up in a 55 or 56? If so, did you use the 3 speed auto. column they sell? Their site states this column is the same design as the stock column.
  2. leadsledjim
    leadsledjim
    from Iowa
    Not sure what Gearheads steering box your talking about but, here is another option. Borgesen make a direct replacement unit with Pitman arm that fits 52 to 64 Fords. borgeson.com to check it out.
  3. leadsledjim
    leadsledjim
    from Iowa
    I just looked at Gearheads Cruisers website and Borgeson may be the same unit and it could save you some cash. Borgeson is a steering parts Manufacturing Company.
  4. rick55
    rick55
    You need to shorten your column to fit the Borgeson unit. With a little fabricating skill you can still use your existing column, but it will take some innovation to get the shift working.
    Regards
  5. Mark T
    Mark T
    If I'm not mistaken Gearhead products was selling a modified 605 GM Box, most of the aftermarket has gotten away from selling these modified boxes because they are troublesome.
  6. Vicky
    Vicky
    from Norway
    Hi Lasbde! I hav used the borgeson steering box and shorten the existing column.Look at the pictures!
  7. ctfortner
    ctfortner
    from West TN
    Just outta curiosity, I wonder how this borgeson unit would work (better or worse) if switching to an ididit column? I have toyed with putting one in.
  8. lasbde
    lasbde
    Thanks vicky, the picts are great. What year Torino did you use for the brakes? I am toying with the idea to use an ididit column also. I would like to have Low, Drive 1 and Drive 2 on the gear selector. Has anyone used an ididit column with the brogeson unit?
  9. ctfortner
    ctfortner
    from West TN
    Maybe someone could shout out to ididit, or even borgeson. Both have been around for years working on things for these older cars, I bet someone knows. Actually borgeson sells columns on their website, only problem I see is none are tilt, which is what I would want. Worse case if we told them what our car is they could say what length column is needed of theirs, and we could possibly match that with a ididit length column. If I get a chance I will holler at them, but I am not close at all to making the swap.
  10. Borgeson unit will not work with a stock clutch linkage.
    TC
