-32 firewall
Discussion in 'The Hokey Ass Message Board' started by Lars, Dec 29, 2005.
  1. Lars
    Lars
    Does anybody know if a p***enger -32 firewall fits a -32 truck.I know that the truck one looks different but are the dimensions the same
  2. alchemy
    alchemy
    Yes, they are exactly the same. Maybe the truck you're looking at is a 33-34. They are definitely different.
  3. Les Moran
    Les Moran
    from australia
    I have interchanged a 32 truck & sedan firewall . the dimensions are the same .
    Les
  4. 3wLarry
    3wLarry
    from Owasso, Ok
    Yes, they are the same...here's a pic of my '32 pickup with a '32 5 Window firewall. Perfect match...
  5. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Can someone show a pick of a stock 32 pick-up firewall...I would like to compare the coupe/sedan/roadster against the truck
    thanks.
  6. alchemy
    alchemy
    Haven't you been listening? The pickup and truck firewalls are the same as p***enger in '32's
  7. Jeff Norwell
    Jeff Norwell
    MODERATOR
    wow..I am really sorry.....I was just wondering if a 32 pick-up firewall was flat at the bottom.....or was it the same kicked out at the bottom like a p***enger car.
    I was just asking pal....
  8. alchemy
    alchemy
    Not trying to be harsh.
  9. Andy
    Andy
    There are early and late versions. The early ones matched side to side at the bottom. The later US versions had the box extension for more foot room for the petals. The foreign firewalls stayed like the early ones as for as I know and that is not very far. No difference between firewalls between p/u and p***. Only early and late.
    Jeff Norwell likes this.
  10. Jeff Norwell
    Jeff Norwell
    MODERATOR
  11. 3wLarry
    3wLarry
    from Owasso, Ok
    Hey Jeff...the pic above of my old truck has the kickout for pedal clearance, so it's the later version.
  12. tommy
    tommy
    the early one.
  13. Mike
    Mike
    Jeez Norwell...pay attention, will ya? ;)
  14. Lars
    Lars
    I did confuse with a 33 which I looked at, thanks for all your help, though.
    Lars
  15. Yeah, you asleep or something? Sniffing the ink again huh?
    But along the same lines, what is the diff between Model B and V8 firewalls if any? Never had the 2 side by side.
  16. Harms Way
    Harms Way
    There were 2 different firewall's on the US produced 1932 Ford, ( as you know now) but the gauge tunnel is longer for a p***enger car, there was 3 variations in frames , 2 different dashboards ( not including the 3/W or P.U.)
    2 Different hoods, 2 different front fenders, 3 different Radiator shells and inserts.( all I can think of now )
    As Ripply would say "believe it or not"
  17. The37Kid
    The37Kid
    I'm no '32 expert but the B motor had a vibration dampener that looked like a friction shock mounted behind the motor. I don't know if the firewall holes were predrilled on all firewalls for B & V8 use.
  18. Mike
    Mike
    Model B firewalls are way different. There is this crazy support/mount type thing that rises up from the bell housing area and bolts to a stud/boss located in the center of the fire wall. Kind of a peculiar deal.
  19. tommy
    tommy
    The only difference that I know of is the location of holes for the different items that bolt to the firewall like that thingie?? in the middle and the gas pedal linkage. The basic firewall is the same.
  20. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Well...I really only need half of one....I will fab the lower portion for foot wells and interior room.
    thanks very much fellas
    Lars...I am gonna email you tonight
    Jeff
  21. fatconnors
    fatconnors
    from easton MA
    anybody know for sure what year this one is? it came off a 1 ton, i thought it was a 32, but now hearing all this stuff about firewalls has made me curious.
  22. Andy
    Andy
    I believe that is a 33/34 firewall. The 32's were separate and the 33/34 were welded in. They also stick out a little for extra foot room.
  23. arkracing
    arkracing
    Yep 33/34. What does the back of the cab look like and does the roof have a screw on the ouside @ the windshild post holding the roof skin to the w/s post?
    If the back of the cab has 2 belt line moldings then it is a '33 if it has 2 + 1 fat one on top...for a total of 3 belt line moldings across the back of the cab than it is a '34
