Engine's in at last!(pics)
Discussion in 'The Hokey Ass Message Board' started by woody, Dec 31, 2005.
  1. woody
    woody
    I know not a big deal to a lot of you, but this is my first one. I think it came out looking pretty good(patting self on back). Tell me what you think. I welded them in with flux cored wire(for better penetration). based on the crummy pics do the welds look good? Lemme have it.
    Happy new year.
    Woody
  2. oneyed
    oneyed
    If all you have is fluxcore you should have put a flathead in it. $25,000 invested will still only get you 300hp.
  3. Woody---Ya did good son. I hope you have a big enough welder in terms of amperage that you got good penetration on the welds. This is not the place to use a candy *** 120 volt mig.
    I always weld in motor mounts with my old 180 Amp Lincoln stickwelder set on about 130 Amps burning 1/8" 6013 rod.
    You will know if you got good enough penetration the first time you really get on the motor, with a hot day, sticky asphalt and big tires.
  4. woody
    woody
    Thanks, Brianangus. We'll see. I'm gonna go with it.
  5. bcarlson
    bcarlson
    Ok... I like the t***les on your shoes. :)
    Looks pretty good, but it's hard to tell from photos. I guess you'll find out the hard way if it's not good enough... It's a very nice start to a cool looking project!
    Ben
  6. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    I use flux core all the way, as does a friend of mine...he has done body swaps with it, uses it for rears (swapping perches etc) and all the motor/trans installs he does...the last being a ripping SBC into a 58 Plym Christine clone that should be around the low 13s, hasnt broken the mounts yet! Looks nice, and I dig the shoes!
  7. woody
    woody
    Thanks guys. The feet standing in those shoes are my dad's.
    Woody
  8. Woody---just for interests sake, what size welder did you use for this welding???
    You seem to infer that flux core wire makes for a stronger weld. All that the flux does is create an inert gas envelope around the weld puddle to prevent free carbon from carbon dioxide in the surrounding air from contaminating the weld. It does not make the weld any stronger. Migs that use a gas bottle and solid core wire are using the inert gas from the gas bottle to do the same thing. Bodyshops prefer the gas mig with solid core wire because there is no flux slag to clean up after the weld is made.
  9. woody
    woody
    Brian, I used a Lincoln weld-pak 100. I'm aware of how the flux does the job of the gas and shields the weld. Now I am new to this and can always use some advice, and every one has a different helpful angle. I appreciate it.
    The reason I went with the flux core instead of switching over to gas is that the welder it self says that you can weld thicker materials with the flux cored wire.
    I would like to have welded it with shielding gas because it is a much cleaner weld.
    Thanks again.
    Woody
  10. bones35
    bones35
    just a suggestion with that small of a welder, i would grind the welds down all the way and reweld using slow wire speed and use the full amps.
  11. woody
    woody
    Bones35, Thanks. I have a friend that is a professional welder. Would it be wise to have him come over and tig it? Or is that not really practical since it's already been mig'd fully? Or I may just do as you said.
    Woody
  12. 30roadster
    30roadster
    you could grind those welds flush and Tig it very easily. Better safe than sorry.
    looking good!
  13. Kind of messy TIGing over flux......but don't let that stop you. Sounds like you have the right people helping you, go for it.
  14. fatassbuick
    fatassbuick
    from Kentucky
    Then again, I had a real world/no Tulsa Welding school theory Model A on Model A frame rails (boxed) with flux core welded motor mounts and a flux core welded Z in the frame that was able to deal with about 400 hp, gobs of Pontiac torque and a 3.50 ratio spooled rear end...and a complete ***** bent on destroying everything driving.
    You'll be alright I suspect. Looks cool, and gimme those power pack heads.
  15. Ayers Garage
    Ayers Garage
    My first welder was a Weld Pack 100 and I used it to install some Mustang II crossmembers a**** other stuff. They are still holding up to this day.
    A trick I use....
    I bought an extra welding hood for my wife to use. She uses the torch and goes in front of where I'm welding to preheat the metal. It makes the welder act bigger than it really is, because it doesn't have to do all the work of heating the metal to molten point with the electricity and wire.
    It's dirty and a hack way of doing it, but it does work.
  16. woody
    woody
    Ha! Thats exactly what my dad said to do. But all I had was a bernzomatic.
    Woody
  17. Ayers Garage
    Ayers Garage
    It doesn't matter. All you have to do is make the metal hotter than room temperature and you're doing some good. I used a Bernz-o-matic for years till I could afford to spring for an oxy/acetylene setup.
  18. woody
    woody
    Thanks, good advice for the future.
    Woody
  19. n95077
    n95077
    Who designed the motor mounts? They look like what I need for a CCR style T-bucket we're building.
  20. CadillacKid
    CadillacKid
    Looks pretty good guy. I guess I'd go back over it with a TIG if I were you...You always want to overkill **** like this...then you can safely say "That's really done" and you can forget about it....Keep up the good work!
  21. DeadFast 33
    DeadFast 33
    from Santa Cruz
    My pants get tight when I see your pics woody.
    FLIP
  22. bcarlson
    bcarlson
    You know, another (possibly problematic) option, might be to finish the build, then _GENTLY_ drive it to a welding shop to have it finish welded. If you have a buddy that can come out and weld it great! I think most folks would agree even using a stick welder on higher amperage would beat the 110v wirefeed. It just doesn't look as pretty as TIG.
    Just my $.02
    Ben
  23. BUICKS38
    BUICKS38
    I used a 110 amp. mig to tack weld my mounts in. I was suprised that the tacks held the flattie. I did that till i got the frame done to stick weld every thing in at a friends garage. But if i was you I think i'd get them welded in with a stck or a bigger mig. That way when your driving down the road you don't have to worry if it's strong enough.
  24. I have never used a tig in my life----I don't have one, and i've never needed one. (I don't deny that probably they're great, but I am only a hobby rodder, and can't justify the expence).
    For body metal I use my 110V mig, for anything as heavy as a frame I use my 110V Lincoln buzz box, and for cutting, t*******, and bending I use oxy acetylene.
    -----Regarding your motor mounts---they will probably be alright---but you must have known before you put them in that your 110V mig is too light for that kind of work!!! Then you post on here, wanting other rodders too tell you that what you done is O.K.
    ----Now you have doubts about what you've done. If you don't get some heavier weld on those mounts now (you can stick weld right over your mig welds using 7018 high penetration reverse polarity rod (if your friend had a D.C. welder) or with 6011 high penetration rod if using an A.C. buzz box.), you will worry about those welds every time you drive the car.
    ---I broke a motor mount once under hard acceleration, and it aint pretty. The motor will counter rotate away from the torque side, tearing up the rear transmission mount rubber on the same side as the broken motor mount---then the top of the ****** will hit the floorboards under your feet and tear them up. If your running a fan, the fan will carve into the rad, and if the motor and ****** raise up high enough during the initial tear-up, the front yoke of the driveshaft will pull out of the rear of the transmission, fall down, catch the pavement and pole-vault the back half of the car upwards and sideways at the same time.
    ---Think about it!!!!!
  25. Dirty2
    Dirty2
    You might want to make some gussets from the mount to the bottom of the frame. I pushed the mount into the frame and it was tiged !!!
  26. stretchnm
    stretchnm
    Woody,
    I`m new to the board but spent years building power plants. There is no need to TIG over your welds. To do that, you`ll have grind them clear out. But you might consider running another p*** over the welds you have. Pre-heat with a torch. Run the verticle downhand (meaning start at the top). You can carry more metal that way and tie in the mount to the frame across the root p***. You can also run more heat. Try it on s**** metal first.
    Just my 2 cents. Nice start to a rod.
    Stretch
  27. woody
    woody
    Uh.... Thanks Flip. Pics of your car make me wet myself. Can we see some more?
    Gang I'm definitely going to have the engine mounts inspected and welded by a pro. I'll disasemble the ch***is and bring it to his house. He uses other methods besides tig. I'm sure we'll get it right. Thanks to all who have given imput.
    Woody
