1952-59 Ford Merc-o-Matic linkage
Discussion in 'Off Topic Hot Rods & Customs' started by strayca631, Dec 28, 2012.
  1. strayca631
    strayca631
    from Norway
    Putting it into my 54 customline I found some of the linkage may be missing and it looks like it should be wire controlled? I can not see any neutral safety switch either, where should it be mounted? Any pictures or drawings would be helpfull!
  2. strayca631
    strayca631
    from Norway
  3. paleot
    paleot
    from louisiana
    I have a 53 Customline, My fordomatic has a neutral safety switch mounted on the steering column under the hood.My trans had two linkages, one to shift one to kick down for p***. I have the kick down linkage if you need it, You can have the whole trans if you want it. Complete from flex plate to front yoke.
    Tony
  4. 1 Ford fan
    1 Ford fan
    Mounts to the lower part of steering column I have a 54 switch and bracket send me an e mail and I'll send picks. gerynviv@pacbell.net Consider a 56 up bracket with a 58 switch, I don't have those but car will start in park and neutral. Gerry
  5. strayca631
    strayca631
    from Norway
    Paleot; I'm afraid the linkage may be different on the y-block and the flathead?
