1952-59 Ford 1.21 2100 carb venturi size for 239 y-block
Discussion in 'Off Topic Hot Rods & Customs' started by sixtyspecial, Apr 8, 2013.
  1. sixtyspecial
    sixtyspecial
    from michigan
    Hello all,
    The carb came off my in car 239 Y and it is a 71-70 truck 1.21 Venturi.
    So, If I rebuild this and put it back on the stock 239 Y will it be too big and cause problems?
    I am ***uming the stock carb was a 1.08 Venturi 2100?
    No history on how or if it ran with this carb. I was told it ran well in the 80s.
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    Probably will run fine with a rebuild,but what is of concern is the intake manifold itself the later intakes with 2100 flange would have larger ports than the '54 heads and may not seal.It may be best to check the codes on the heads and intake to see how they match up http://www.y-blocksforever.com/index.html
  3. sixtyspecial
    sixtyspecial
    from michigan
    Thanks. I didnt even think that it was a replacement manifold. Thought the 2100 is a direct replacement for whatever carb was on there. Old fords are new to me. I have a pic of what I am dealing with but it looks like I have to have a picture hosted to post it.I will go and read the site instructions and return.
  4. the-stig
    the-stig
  5. sixtyspecial
    sixtyspecial
    from michigan
    Thanks stig I will put up a avatar pic and all that while I am at it.
  6. sixtyspecial
    sixtyspecial
    from michigan
    Here is a picture of the manifold the 2100 was riding on.[​IMG]
  7. streetdreams
    streetdreams
    The 1.21 is too big for a 239. The 260 SBF had a 1.01 and the 292 2bbl I think ran a 1.08.
  8. Ole don
    Ole don
    That is not a 239 intake, and those are not 239 rocker adjusters. You may have to remove a head and measure bore and stroke to know what you really have, or it could be a modernized 239. If the motor ran good with a carb off a 272 or 292, one could ***ume that's what the motor really is. Try to find a casing number and check dates.
  9. JeffB2
    JeffB2
    from Phoenix,AZ
    I posted a link above to help you with the codes,please post your results when you get them broken down.
  10. Custom_Crestline
    Custom_Crestline
    Yeah, those are for sure later rocker lock nuts, and judging by the ford engine blue, it could be anything. Be happy that it might not be an EBU or EBY. I bet its going to be like an EDBE or something of that ilk, with that intake.
  11. sixtyspecial
    sixtyspecial
    from michigan
    Thanks everyone, I have had it for a short time and have a long distance relationship with it til I can save up to get it shipped. My friend is picking away at it for me. I will try to get some #s off it.
  12. sixtyspecial
    sixtyspecial
    from michigan
    Partial # off intake is -9425-B
    So I guess that equals 1955 272 2V
    That's all for now
