1952-59 Ford Question on routing wires thru rocker panels
Discussion in 'Off Topic Hot Rods & Customs' started by Skeetum, Apr 14, 2013.
  1. Skeetum
    Skeetum
    I have just about completed fabricating repairs on my lower 'A' collumns and wonder what size holes to use to route the wiring thru. Should I use the original size hole and grommets/hardware or something different. I appreciate your comments and suggestions.
  2. Ole don
    Ole don
    I would leave them sealed up. All the wires in my car are run under the carpet inside.
  3. Paul2748
    Paul2748
    I ran my wires under the carpet 2
  4. rick55
    rick55
    From factory ,they are run down the transmission tunnel under the carpet and go down the left (drivers side) to the trunk.
    Regards
  5. chopd top
    chopd top
    from Florida
    X 3 on under the carpet. My old ones were run just like yours, down the rocker panel. If your set on running them the same way, a 5/8" hole should be plenty big enough with a grommet. Looks good btw!
  6. 38chief
    38chief
    from canada
    *****um
    My 54 (original car) has the wires running along the engine side of the firewall and thru the lower hole in the A column, then thru the rockers to the rear of the car. Not sure what the upper hole is used for, mine just has a rubber plug.
  7. PaddycakeFTW
    PaddycakeFTW
    My original '54 wires go out through a grommet on the driver's side, above where the kick panel would be, then down to the lower hole in your picture and through the rocker to the trunk. Not sure if the upper hole is there on my car or not - if so, it's plugged like 38chief's.
  8. merc-o-madness
    merc-o-madness
    yeah leave it sealed up, that hole probably starts all the rust
  9. ThomasN
    ThomasN
    from spokane wa
    I just put new rocker panels on my 53 vic and I put a 3/4 in emt full length so I can run my wires in metal conduit to the trunk. I will seal both ends with duct seal. I tack welded the conduit to body metal, put bushing on both ends.
  10. Skeetum
    Skeetum
    Ok thanks for all the input. Sounds like a variety of ways to do it.
