1952-59 Ford New guy, old build story
Discussion in 'Off Topic Hot Rods & Customs' started by rwd_pete, Jun 13, 2013.
  1. rwd_pete
    rwd_pete
    I signed on a while back, but it took a while to figure out picture posting. I live in Ontario near Niagara Falls. I'm just getting my 56 Victoria back on the road.
    It started back in 1966 when I bought a 29 Ford coach when I was in Grade 12. It was in the ba*****t of a cow barn with only one light bulb. It looked ok and ran for $275, but once out in the sun it had bondoed over paper bags stuffed into holes, was flat black and leaked badly out of the rear seal. It took a year to replace the engine, fix the body and paint it. It would go 62 mph flat out and ran quite well.
    I started university 80 miles from home in Sept. 67 and commuted weekly in the A.
    All was well until I got caught in an early November snow storm. No heater, no defroster, snow packing around wiper from the top. I spun it 360 in traffic with big bald 900 Royal Masters on the back. I needed a winter car.
    My friends all had 56 Fords. Ones ready for the s**** yard were $20 and we had 6 parts cars. I bought a Victoria with Tbird 312 auto for $125 for my winter car.
    The car has evolved a bit over the years.
    Pete
  2. rwd_pete
    rwd_pete
    The 312 was leaking oil out of the rear seal. I pulled the trans and the pan to fix the rear seal. While tightening the trans crossmember bolts back up I heard a cracking noise and trans fluid leaked down onto my face. So much for the auto. From our parts cars I switched it to a 3 speed standard with a Foxcraft shifter.
    The motor was burning oil and I bought my budies rough 56 post for his 272, 312 heads. Later in '68 for more power I bought a 55 Ford for it's 240 hp 57 Merc 312 for engine #3.[​IMG]
    I think I paid $50.
    A friends dad had a 56 wagon, 6 stick with a blown rear end. We swapped in one from our parts cars and the old wagon rear was a 4.11. So I repaired it and put it in my car. I recall some trans syncro" dogs" popping out on the way to university. It wouldn't come out of high gear. I drove it that week parking in drive-through spots and feathering the clutch from stops signs until I got back home.
    While at school driving around, the front end started to shake. The crossmember had cracked across the A arm bolt hole. Having it towed 80 miles home would be pricey. I hitch hicked home and borrowed my brother-in-law's 5 ton farm truck. I found a constuction site with earth piles. I had brought some planks and shovels, and we made a ramp to load the 56 onto the stake truck. Back at the farm they had aloading dock to offload it. The car that had provided the 272 had a new crossmember, so it went into the Vicky.
  3. rwd_pete
    rwd_pete
    I was taking co-op engineering and worked 4 months and went to school 4 months. By February '69, the Vicky needed more power. I bought a 390 4 speed from a 62 Ford Galaxie rag top at a wreckers for $300. By April it was running, but used a quart of oil in 60 miles. The wreckers replaced the engine with a 64 Merc 390 for engine #5. In Sept 69 the engine came out for a rebuild. 67 Mustang 390 GT 10.5 pistons, Cobra jet C8AX 6250C cam, Edlebrock F427 intake. I bought a set of flanges and built fenderwell exit headers for engine #6.
    I welded the back half of two front wheel wells togther for radiused wheel wells. I added a Cobra Jet Mustang hood scoop and had the hood painted flat black like Mach I's and the car painted Chrysler bright bronze in 1970.
    The rear wheels were magnesium 10 x 15 Americans that came from a top fuel car that a friend bought in Lockport New York. Another friend had the latest Mickey Thompson J70 x15 tires on his Deuce coupe. I swapped the bigger M&H's for the more streetable Mickeys.
    By then I needed a new winter car and bought a 69 Fairlane Cobra for $400.
    The Vicky ran low 15's at the drags.
  4. the-stig
    the-stig
    Welcome from So Cal. Nice cars and good story.
  5. 1956Ford
    1956Ford
    Good hotrodding. Welcome the group from Nor Cal.
  6. JeffB2
    JeffB2
    from Phoenix,AZ
    Cool story! Love the Pix! :D
  7. flyboy89
    flyboy89
    from So. Cal.
    SoCal welcomes you.
  8. 54_cussy
    54_cussy
    I am only new myself, great to read the story of your ride and hello from Australia.
  9. 1 Ford fan
    1 Ford fan
    great story welcome from So Ca..Gerry
  10. rwd_pete
    rwd_pete
    Thanks for the welcome. I'm glad you like the story. Here is the next chapter.
    In 1971, after a day at the track the 390 got a rod knock. It had a spun rod bearing. I had a friend that was a mechanic at a Ford dealer. He had a 428 Cobra Jet Fairlane drag car and had a spare 428 block and stock pistons. I didn't have a 428 crank. He said I should order a reground crank and bearings from the dealer and put the 390 core back in the box. It worked. I took the 428 block, crank, and pistons plus the 390 rods and flywheel to a balance shop. The shop called me soon after. The crank was out of balance about 1/2 lb. on the front. From my mechanic friend I learned there are CJ's with with convential rods and drag pack Super CJ's with heavier 427 cap screw rods and have an externaly balanced crank. They use a counterweighted sleeve behind the harmonic balancer. With that part it all got balanced. I had to save $1000 in my work term to pay for the next four months at school back then, so the stock 390 heads went back onto Engine #7.
    I had about 50 easy miles on the new 428. On my way home from work I had to drive through the Thorold tunnel that is under the Welland ship c**** that connects Lake Erie and Lake Ontario. Just as I entered the tunnel I heard a bang and the engine stopped turning. The Vicky coasted to a stop at the bottom of the tunnel. Because of the curve under the c****, I couldn't see daylight in either direction. A big truck made a hard stop behind me when I came into it's view. I got out of the car and onto a walkway. Shortly after, a service truck came up behind me and pushed me up out of the tunnel. I guess there was closed circuit TV. It was kind of scary.
    I had the car towed home. A valve head fell off, turned sideways, split the piston and cylinder wall. I had the block sleeved. In '69 there were four 428 piston weights, but none met my balanced piston weights. I bought a lighter piston. Back at the university lab I machined aluminum bushings. I put them in liquid nitrogen and interference fit them into the piston pin ends. I bought a set of 428 heads from a drag racer. He said the valves had sunk too far from frequent rebuilds for racing. A friend had picked up an Edelbrock FE 2x4 intake leaning aginst a trash bin on cleanup day. He gave it up for $20. So the dual quad 428 engine combo#8 went back into the car.
    Sometime later in the early '70's I repainted the car black laquer with flames in our garage.
    [​IMG][​IMG]
    Weekly I towed my friends 70 429 CJ Torino to the track. The Torino ran 13.20s. The Vicky tow car ran 14.89 @94 through the bumper outlet exhaust. With headers open it ran 13.89 @103 mph. It had a 3.08 9" rear from a 57 Ford.
    At a wreckers I found a reupholstered 57 Ford interior. It wan't a good fit, but I made it work. The dash was krinkle black.[​IMG]
  11. skoh73
    skoh73
    Wow man, great stories with great pics to boot! Thank you for taking the time to upload and share.
