1952-59 Ford Flex Plate Problems
Discussion in 'Off Topic Hot Rods & Customs' started by RANCHWAGON55, Aug 23, 2013.
  1. RANCHWAGON55
    RANCHWAGON55
    from sacramento
    I could use some.. I bought a 302 and a AOD off of craigslist. They came out of 1985 ford pick-up. At least that's what I was told. Since then I've had the engine and transmission rebuilt. My problem is that I'm having a hard time finding the right flex plate. Napa Auto aren't sure if they can get the right and I called the ford dealership in town and they aren't sure if they can get the right one. My question is, does anyone know the right part number? I'd like to drop the engine and ****** in, in a few weekends. Any help would be appreciated. Thanks, Zach.
  2. JeffB2
    JeffB2
    from Phoenix,AZ
  3. old lady's mad
    old lady's mad
    any transmission parts supplier in town should have it. kmj has a good unit ant of the speed parts places should have it. need to make sure what year you have. as around 81 there was a balance weight change and it will vibrate if you guess wrong. also the balancers are different.
  4. Retro Jim
    Retro Jim
    Zack ,
    Don't know where you live but there are 2 different size flex plates Ford uses and the AOD is super easy to find .
    I am not sure where you live but I am in Pa. and I have one hanging on the wall with a block spacer plate . If you need one let me know . The 157 tooth is the common one for C4 and the bigger 167 or 8 tooth , can't remember , is the one you need so there is no problem getting one .
    heck Summit , Jegs , Evelbay , Rock Auto all carry that flex plate so don't worry , it's far from anything that hard to find , rare or obsolete !
    Here you go -http://www.jegs.com/i/B%26amp%3BM/130/50238/10002/-1
    It's $65 !
    Jim
  5. JeffB2
    JeffB2
    from Phoenix,AZ
    The AOD's are all 164 tooth,the 157 tooth was used on earlier C4's those can get a little tricker to match up in some cases because Ford did some weird converter changes and some will not interchange,later C4's with the large bell housing also had 164 tooth flexplates but stockers were 28oz balance as are the AOD flexplates from a 5.8 aka 351W the later AOD's from a 5.0 are 50oz balance.
  6. RANCHWAGON55
    RANCHWAGON55
    from sacramento
    Thanks for the feed back guys. I should also mention that I didn't have the engine balanced during the rebuild process. Is that going to cause any issues?
  7. JeffB2
    JeffB2
    from Phoenix,AZ
    As long as you still used the 1985 crank and a matching 50oz harmonic balancer you are good to go.Then the parts I listed on the 2nd post will do the trick.
  8. RANCHWAGON55
    RANCHWAGON55
    from sacramento
    Thank you Jeff!! Looks like I have some homework to do.
