Anyone have a wiring schematic for the '55 wagon? I've searched and can only come up with a '57. Thanks Bruce
Click on this:http://www.jalopyjournal.com/forum/album.php?albumid=40980 the 52-54's used the same color coding as the '55 and are almost identical. To make it EZ to read and since it will print out at 8 1/2" X 11" for about $6 most Fed-Ex stores can blow it up to 11" X 14" and laminate it that way you can take it to the garage and just wipe off any grease.
When you click on it and it enlarges you will see a color chart that corresponds to the code on each wire.
Were you looking for the total wiring diagram or for a specific area? I have an electrical ***embly manual for the 56 and can scan any drawing you need if you need some other area or something a little less cluttered. I don't know if it's the same as the 55.
