Ok so I got my Aerostar springs on, 3 inch blocks on the back and new shocks all the way around. 12 volt harness from rebel wire, T5 adapters on order as well as a larger sway bar and a 9 inch coming soon. Are there any other cool tricks out there while I have this thing apart that I should look into?
How about a Duel Master cylinder for your Brakes. A Disk Brake kit for front also could be done. And then there is Power Brakes. You Could add a Power Steering Box by Borgeson. Its a bolt on with only changes to Steering Shaft and fab up a bracket & PS pump. Maybe Air conditioning for those hot Days. Always something to do. It never seems to end.
If you want to do a simple upgrade to your brakes. Check this out. I did it to my 53 and it works great. http://www.youtube.com/watch?v=wXfXKlj2D1I
Demon it's the 1 1/8" by Jamco http://jamcosuspension.com/products/sfID1/73/sfID2/39/sfID3/15/productID/339
There are two ways to tackle the switch issue,one is to install a "T" fitting in the new line you added on the other is to fab up a bracket under the dash and use a GM style adjustable switch which is a better alternative if you have installed a new 12 volt wiring harness,there are pictures of this in our archives.
There is 3 parts to those videos. The guy mentions all the parts you need. I just asked for a 67 Mustang with a 289. For the brake switch I put a tee fitting inline with the front brake line out of the master cylinder.
What does matter is the master cylinder part number in 1967, the Mustangs used both drum/drum and drum/disc brakes if you match them correctly you will not need a prop valve and also there were power and non-power brake options.The video was for a drum/drum non power application.
I used a drum/drum dual non power bowl from a 68 Mustang and used a pressure switch for the brake lights. Works great, the only thing I had to change was the push rod, I believe it wasn't long enough. I got mine from a local cl***ic mustang spe******t but you can get it from here. I also upgraded to a jamco sway bar since my old one snapped. I wish jamco would make a rear sway bar for our cars! Looks like they skipped '52-53!
For brake light switch( autozone parts are garbage,get NAPA) Ask for a 65 Ford F100 truck(240 6 cyl) with drums. You'll probably have a hard time finding a tee that has the thread to screw in the brake switch. I modified a 3/16 brake line br*** tee. On the side I drilled open to tap a NPT 1/8-27 thread and that worked out as my inline tee. That tap comes in almost every tap and die set.
About the brake "tee" guess who has a better selection in br*** fittings than most parts houses? Ace Hardware! Got all mine for the dual master upgrade there.
