Hey folks, do any of you have any reputable suppliers for door hinge rebuild kits? My builder is in need of some for my DinerLiner project as he says the bottom hinges are different to the pick ups by the looks of things , Will also be needing door seals and window seals/felts, so any suppliers of those would be useful. Would prefer the best quality over the cheapest - it gets wet in the UK and I like to drive fast without wind-whistle in the cab! Cheers Mack
Morning Mack, I have a '47 COE it appears the lower hinges are made from the original pick-up lower hinges. To me it looks like they just put a 90 degree bend on the lower part. I'm pretty sure the pins are the same as the pick-up, at least for the lower ones. For the door seals and window felts they are the same as the pick-up but need minor mods on the lower part. I got mine from Cl***icparts and am happy with them. Good luck, Rob
Thanks Rob - I've been reading up on all the seals I'll need for the doors/windows and there are far more than I anticipated - typical! Putting together a full list of parts I need so will check out Cl***ic Parts. Hopefully I can get everything from one supplier but we'll see... Thanks again for your help Mack
