Hot Rods 1931 Model A The Harbor Kustom's Coupe, A "Bonneville/Rolling Bones" style build!
Discussion in 'The Hokey Ass Message Board' started by HarborKustomSpeedShop, May 5, 2014.
  1. So I had an opportunity to buy a 1931 model body, full hood, 32 grille and a 32 frame. For running gear I'll be using 1941 ford front and rear axles, 59A-b flathead V8 with a 39' 3 speed top loader transmission hooked to 41' pedals. The ch***is is pinched to fit a model A and then the frame horns were removed and the rails pinched more to tuck them in where the hood sides will be. It will ride on 35-36 (I believe) wire wheels with 750-16 rear and 500-16 ribbed dirt track tires up front.
    Here's the pictures so for, Im currently working on the ch***is.
    frame getting Jigged up
    Pinched to fit model a cowl
    Horns removed and pinched to fit 32 grille
    Had to throw the grille on to see what it looked like
    At first I was going to use the 1941 ford x section
    here's some of the mock up pictures
    However I didn't like the looks of it and how it didn't flow back into the ch***is right on the rear. So I made my own.
    Starting to take shape
    kidcampbell71 and volvobrynk like this.
  2. Next it was time to make some motor mounts
    Then I checked fit and started to set up the clutch arm and linkage
    That's were I am currently
    Justin
  3. gnichols
    gnichols
    from Tampa, FL
    N I C E start. Sub'd. Gary
  4. badshifter
    badshifter
    Looks good, nice work.
  5. fastmike
    fastmike
    from Mesa AZ
    Great work man, those motor mounts look killer!
  6. The37Kid
    The37Kid
    Looks great, who carries that front crossmember you are using? Bob
  7. Thanks guys!
    Bob I got it from so-cal speed shop
  8. brady1929
    brady1929
    Man that is some nice work.
  9. PurdueSD
    PurdueSD
    Those motor mounts kick ***!
  10. Martin_F
    Martin_F
    Nice build!
    Looking forward to the updates!
  11. Doc.
    Doc.
    Very nice work. Subscribed.
  12. lothiandon1940
    lothiandon1940
    Fabulous! Will be watching the progress.
  13. Very nice work!
  14. the violator
    the violator
    Very nice ! i have a similar collection of parts that i'm thinking of going in the same direction with. Please keep the photos coming!!!!
  15. Nice clean start. Subscribed.
    porky55 likes this.
  16. Good looking start! I'll follow along.
    porky55 likes this.
  17. Skidder
    Skidder
    Very Nice start. I subscribed.
  18. Well I worked on the frame this weekend got the x member 95% done just need to get some tubing to bridge the top together. Got the pedals mounted and got the side/supports made and welded in. I also got the rear 2 feet of the frame boxed. Also got the tires in and I mounted them a work this week ill get those pictures up this weekend.
    Here's the pictures
    Thanks for looking
    Justin
    skinnydude likes this.
  19. Squablow
    Squablow
    Frame looks very well built and I like the plans. Any pics of the body? Was it mentioned if it was a roadster, coupe, sedan?
  20. oldman2
    oldman2
    Justin, just now found your new build, will be along for the ride...Jim
  21. Flipper
    Flipper
    from Kentucky
    Looks like it is going to be one hell of a car.
  22. thanks Its a coupe, no pic at this time. hoping to get the body in a week or two...
  23. Thank you
  24. da34guy
    da34guy
    Great lookin so far
  25. banginona40
    banginona40
    Great project! I need another Model A.
  26. Leon Sandcastle
    Leon Sandcastle
    I love the craftsmanship
  27. El Hueso
    El Hueso
    Very cool! What rearend are you planning on running?
  28. Thanks guys, I've got a 41 ford banjo rear end
  29. Apittslife
    Apittslife
    Kewl, I am Subscribed!
  30. Bentrodder
    Bentrodder
    from Cotati
    This looks like it's going to be a good one! Subscribed!
