Features 250 INLINE 6 "lets see em"
Discussion in 'The Hokey Ass Message Board' started by roosters hot rods, Feb 10, 2008.
  1. Twisted6
    Twisted6
    Welcome to the Board.
    What intake are you running?I have never run a heat plate here in fla.The intake get more then warm enough on its own.And I have run the Offey and The clifford intakes.Up to the point I now run my own Custom built 3x4 tunnle ram intake.The exhaust will get heat to the intake faster then water, Only beacuse how close the headers are to the intake.BUT the water keeps a more even heat to the intake.
    Hope this helps.
  2. 1970nova250
    1970nova250
    its just a stock intake from 1970 not sure the name.
    Hoping to upgrade to a 4 barrel from my one barrel carb,
    but thanks for the reply and help i figured i wouldn't need one ,
    but just to make sure i asked.
    thanks!
  3. Twisted6
    Twisted6
    The stock intake has a built in heat riser from the stock exhaust.But it will still get hot from the headers.Or make some form of heat tube to set over the header to the bottom of the intake.
  4. 1970nova250
    1970nova250
    okay thanks for the info much appreciated !
  5. Hammer76
    Hammer76
    from MILANO
    Hi guys
    this is my 250
    Weber DCOE 45
    Hnstray, kiwijeff and 1963hoopty like this.
  6. mink
    mink
    from CT
    What timing are you'll setting your stock 250 ci engine at. 4 deg BTDC?
    Im curious to know what i should set mines at with the manual ******
  7. Twisted6
    Twisted6
  8. mink
    mink
    from CT
    Heres a shot of my project. Don't pay any attention to the fuel line, it temporary.
    It'd be nice to see how others plumbed their clifford intake
  9. NEWFISHER
    NEWFISHER
    from Oregon
    All the bells and internal whistles. 19 mpg and 26,000 miles since last December.
  10. rodhot
    rodhot
    I know this is an older thread but wanted to show off some.
    Intake right after grinding and first round of wet sanding with 320.
    Intake after final sand 1500.
    First round of polishing rough cut.
    Second round medium cut.
    After final polish.
    Finally in car but just bought a totally rebuilt and 30 over bored 250 so doing a motor change coming up.
    Did install a 200 4r when I put the 194 in. Damn, I finally did something smart on this ride doing that. Hope you all like.
  11. Fingers
    Fingers
    Like it a lot:)
  12. rodhot
    rodhot
    Thanks Bro!!!
  13. 1963hoopty
    1963hoopty
    Heres my stock 230 with my homemade header. Gettin dual carbs an lump ports soon!
  14. Twisted6
    Twisted6
    Great looking header Nice Job on it.
  15. johnnymac1
    johnnymac1
    Finally got it together and fired it yesterday, .040 over 250, decked, flat tops, lump ported, 1.94 valves, shaved the head .030, street ported, triple angle valve job, headers and carbs. Love the sound can't wait to drop the cab on it. IMG_20160727_171811188_HDR.jpg IMG_20160727_144610006.jpg IMG_20160727_144554805_HDR.jpg
    kiwijeff, sharpmark and belair like this.
  16. rusty1
    rusty1
    .you guys have some great lil motors,....I've always liked Chevy inlines,...this is my 48 F-1 with a 250,..I'm not into shine, just love the reliability and great gas mileage these things get,...they just purr down the road.
    simplicity at it's best.
  17. Dan in Pasadena
    Dan in Pasadena
    Not mine.
    Stolen off another website for trucks. It is in a '67 Chevy stepside shortbed. Maybe it'll piss off a few of you for being too billet-y. But. Think it looks great. I'd be proud to own it.
  18. Jethro
    Jethro
    I love the look of those gl*** bowl Holleys!
  19. chobro
    chobro
    from ABQ, NM
    Looks sweet! What trans is that? S10?
  20. 1931fordtruck
    1931fordtruck
    That is one bad lookin' motor. What model truck cab are you using?
  21. Happiness is a Hot Rod Hudson1 I have 7x 308 with lots of up-dates done to it! It will run hard & Fast! Uncle Bill
    kiwijeff likes this.
  22. johnnymac1
    johnnymac1
    Dependibility is the name of the game for me, I just added a little kick to it, the transmission is a Borg T5 form an 86 V8 Camaro IROC with the S10 tail housing, the cab is a 34 Ford, it's gonna drop 4" and chop 4" I needed to run the motor and get the bugs worked out of it, make adjustments and take care of any leaks. The carb covers are boat bilge vent covers with a little home built touch to make them fit. I have the carbs set up so the center is the primary, front and rear are secondaries. It's my first build and it's been a blast so far, homemade frame, the big items are store bought, like the front end, it's a Lucky 7 I beam, 4" drop, disc, hub to hub deal, rear is a junk yard Ford 9" with factory discs. Box is a 32 that I shortened, I took 3 inches out of the front. Hand built bed floor, thanks for the comments.
  23. woodbutcher
    woodbutcher
    :D Have had more than a few v type engines.Just keep coming back to the inline 6`s.
    Good luck.Have fun.Be safe.
    Leo
  24. 1pickup
    1pickup
  25. 100fires
    100fires
    What kind of intake?
  26. Hnstray
    Hnstray
    from Quincy, IL
    62E4BB07-B60B-434C-A4FA-5B965BD3711D.jpeg D078DE66-FABA-4D24-AB7E-0456649DFA79.jpeg 0A9AC4E1-6FA1-40D1-A21B-2D50F8F84A24.jpeg
    250 Chevy, mild bore, flat tops, slightly bigger valves, intake bowl cleanup, lump port mod, roller rockers on pivots and tips, RV torquer cam, Aussiespeed manifold, Edelbrock AVS2 500 cfm, Pertonix ready to run, 12Bolt/Langdon headers, dyno’d 258 lb ft, 226 hp......going into my ‘37 Chevy Coupe.
    Ray
  27. Twisted6
    Twisted6
    That looks Sweet. I like the extra oil feed line.
    Hnstray likes this.
