Wishbone Bungs for 1928-34 Early Ford Tie Rod Ends
Discussion in 'Parts For Sale' started by CTaulbert, May 17, 2014.
  1. CTaulbert
    CTaulbert
    from Detroit
    City: Shipping to Anywhere
    State: Michigan
    Price: $65
    photo by Geoff Miles
    The first split wishbones used '28-34 Ford tie rod ends. Back then, it was common to weld in a cut down tie rod. While it was functional, it left a lot to be desired aesthetically. I started machining a custom bung that offers a smooth transition between the wishbone and tie rod end.
    The bungs are machined from mild steel, and come chamfered ready to be welded to your already split wishbone. Make sure you chamfer your wishbone, and use a 220v welder (and a competent welder) to weld them.
    As you can see from the photos, these bungs have quite a lot of design work and machine work in them - and they're PATENT PENDING....so no one knocks them off at a sacrifice of the quality I put into these.
    The bungs are $65 a pair, plus shipping. I ship UPS flatrate, which is $11 to anywhere in the US. I can also ship internationally, but PM me for the best rate.
    PayPal is the easiest form of payment, but I can do a Money Order too. I only do small runs at a time, so don't hesitate if you're interested. Send me a PM or email for more information or to order.
    dlw1932, RICH B, john potter and 11 others like this.
  2. CTaulbert
    CTaulbert
    from Detroit
    OUT OF STOCK
