Projects 1934 Ford Sedan Gender Reassignment Surgery
Discussion in 'Traditional Hot Rods' started by flatnasty, Jan 14, 2014.
  1. st.rod
    st.rod
    Way more talent than I will ever have. Amazing!
    Larry
  2. texkbc
    texkbc
    great tip...thanks
  3. MIKE-3137
    MIKE-3137
    great work!....I love this kind of build thread...awesome
  4. Hey the car is coming along awesome! I had the chance to see it in person and it looks killer !...... you just had to chop it a bit more than mine didn't you.....lol
  5. flatnasty
    flatnasty
    from Vancouver
    image.jpg pics 019.jpg pics 024.jpg pics 028.jpg pics 027.jpg pics 026.jpg Thanks everyone! Everyone has been great support and I have had some good tips and tricks from lots of you.
    Went to town on car stuff this weekend. I spent all day Friday in the shop. Now that the roof is pretty well back together I got my attention pointed towards the doors. I started by crossing my fingers and cutting the doors open. Everything still lined up nice. Before I got too carried away with the door tops I decided to finish the inner A pillars and get the above the door tins and wood mocked back up and working. By the time I wrapped that up Friday was shot. Saturday I went to a swap meet. Scored a Brake drum 33 front axle and some 32 king pins and a model A headlight bar that was cut up. Sunday Back to the shop and tackled a door top. It was fairly simple all things considered. A million slices and a bunch fitting welding and grinding and It was good to go pics 026.jpg pics 026.jpg pics 027.jpg pics 028.jpg pics 024.jpg image.jpg pics 019.jpg pics 024.jpg pics 028.jpg pics 027.jpg pics 026.jpg image.jpg pics 019.jpg pics 024.jpg pics 028.jpg pics 027.jpg pics 026.jpg .
    ls1yj, Pufff and mauler rich like this.
  6. HarborKustomSpeedShop
    from Olalla, WA
  7. tub1
    tub1
    from tasmania
    what a cool car well done
  8. Keep going. And thank you for the updates.
  9. flatnasty
    flatnasty
    from Vancouver
    Well fellas just thought Id say thanks for all the encouragement and let you know that I haven't been slacking off on this thing. I was able to get the other door top on over the weekend. It was a **** ton faster on the second side, since their was like half the head scratching this time. Turns out I was slacking by the looks of it. Slacking on the pictures! Fak sorry. Ill get some coming. Next up will be fire wall and a bunch of fiddly **** i Have been avoiding on the chop.
    Brad
  10. thunderbirdesq
    thunderbirdesq
    You're doin a great job man, looks killer!
  11. Troublemaker427
    Troublemaker427
  12. sko_ford
    sko_ford
    That Is a hell of a chop man. Diggit
  13. Asphalt Demon
    Asphalt Demon
    from Australia
    Besides the great job on the conversion to coupe! what an incredible wedge chop,i love the way the front of the door flows radius to radius with no flat/straight section,its no easy feet to get that.form ,function,flow on a wedge chop like that,this is gonna be interesting when painted,man stance ,ch***is setup and wheel tyre combo are gonna make/break this! can't wait to see which avenue you take.great free thinking .johnny
  14. Roger53
    Roger53
    This is one of them changes alot of them poor old mixed up four door cars dream of getting some day. Keep the pic's coming it's great of you to take the time to do it. Roger
  15. flatnasty
    flatnasty
    from Vancouver
    During the week this week I worked on my door latches. They were all completely seized, and all the strikers were totally shot. When I bought the car The only unbolt-able part that came with the car was the cowl vent ***embly and the rear door latches. So I drilled out the strikers on the rear latches and put them into my completely ****ed front latches. Then I got everything all unseized on the p***enger side and it working real nice. The driver side however was missing all of the mechanism that engages the latch. So between the welder, the grinder and a few old latches I had around, I was able to get the driver side up and running. That was an all day cluster ****, but it turned out nice.The rest of the weekend I want to get the last of the welding on the inside of the door tops finished up.It's always nice when you get the doors swingin!
    Brad
    Pufff likes this.
  16. pumpman
    pumpman
    Impressive as hell man, I just burned an hour reading the thread and it was well worth it! Your work and eye for detail is just spot on. I have a dumb question because of my curious mind, how much sheet metal is left from the 4 door back half?
  17. flatnasty
    flatnasty
    from Vancouver
    This weekend was a busy one over at my house but I was able to get an afternoon in of the old hot rod. I Patched up the firewall. Over the years someone figured it would be a good idea to drill, punch and butcher holes into the firewall. So I had to patch them up. There was 2 big holes for heater hoses that were put write through the reveals in the firewall. I was able to find the matching reveals to patch them in the inner rear door skin that was left from when I cut up the rear doors to make the quarters. Then I fixed some rust in the below the decklid panel. pics 123.jpg pics 127.jpg pics 129.jpg pics 143.jpg pics 141.jpg
    Pufff likes this.
  18. Very impressive work. The sloping roof angle and front of the door window openings looks great -
  19. Super inspiring!!!
  20. flatnasty
    flatnasty
    from Vancouver
    Switching gears on the car this weekend. I'm finally at a point where I can get onto something aside from body work. I shuffled the car over to the other side of the shop this weekend and lifted the body off the frame with my hoist. Then I got to work on getting the motor and ****** set in the rails. I picked this motor up off a fella in Portland a while back. He told me it came out of his restored 39 ford he bought off a older fella. The story goes, the motor was a nos crate motor before it went in the 39. It was suppose to be for a 46 ford crate motor. However when I got there It was no 59ab out of a 46. It turns out it's a 99 motor. I lucked out there! Anyway it came complete with all the front suspension the ******, diff and all the mint orig wiring. He pulled it out for all his street rod stuff. lol Gotta love those street rodders! Any way I plan on using the motor,******,diff and wiring in the car. The front end I sold off a little while ago to recoup cost on the rest of it as it is no use to me.
    My engine crane packed it in a while ago so I had to lift the frame over the engine. Kind of a pain in the *** but it worked.
    047.jpg 049.jpg 051.jpg 053.jpg I was pretty happy to seem my fan that I had was going to fit perfectly. 055.jpg I borrowed my friends 34 torque tube for mock up. I'll have to shorten the 39 when I get to that. 057.jpg
    Brad
    kiwijeff and Pufff like this.
  21. alchemy
    alchemy
    You would think it's gonna be a good combo, but even with the chop your body seems to sit a bit high. ;)
    Outback likes this.
  22. Fogger
    Fogger
    Great project, what Hot Rodders don't want the Street Rodders can use and visa versa. Looking forward to your completion.
  23. Squablow
    Squablow
    Great progress, looks good. What is a "99 motor" when referring to a flathead? I've never heard that term.
  24. kidzintha34fodor
    kidzintha34fodor
  25. kidzintha34fodor
    kidzintha34fodor
    99A is 39-41 merc if I remeber and 99T is a truck block . Thicker bores than the standard Ford
  26. Looking great Brad! I want to go for a ride when its done!
  27. kidzintha34fodor
    kidzintha34fodor
    Man! looking good! You should see if you can talk Dave out of the floor! I see why he wants it, but it makes a lot of work for you!
  28. JasonCarGuy
    JasonCarGuy
    Why wouldn't you just buy him a new 34 floor? Have you tried that, then you don't have to cut that one all out and he gets a new floor, win win...
  29. hotrod_tommy
    hotrod_tommy
    I've been soaking up this and other "coupe-izations" and am now underway on my '34 Stude. 5-w coupe is the end-run, dream ride for me. No idea yet how I'll finish the top of the rear qtrs., but hoping to get access and time to learn on an English wheel at area shop. The Stude doesn't have a beltline rib, but a crease (sort of like '37 Ford?) so I can't just stick on Ford quarters, even if I could afford 'em.
    Had been on hold while ***le bonding process dragged on, but now have ***le in hand, so I have to sell off some of the fleet to pay for this, but let's boogie! ALL excited like a teenager again. I need that at this age. hahaha.
