I have seen several pictures of the Model A in Bonneville threads over the years. But that is all I found right away. I am not sure but I think the other car is a Buick and may be from Russia. Long tow. PS I ran a Dodge Hemi with a T frame at Fremont plenty of times. That was then. Now i would not do that.
Maybe thay weren't Hot Rods but the Straight 8 Buick two man cars did well at INDY in the 1930's. A restored one with a HAMB member driving it holds most of the Vintage Hillclimb records in the VSCCA. Bob
In the early/mid 60's, one of the members of a firetruck manufacturer's family (Seagraves?) ran a Buick straight 8 very successfully in the lower altered cl***es. It might have run E/Altered as that was a catch-all cl*** for the odd stuff. It was in front of a roadster body. The length of the engine looked out of proportion to me though I liked the car as I've always been a fan of underdogs. My recollection is it ran in the low 14's/high 13's. Sorry my memory isn't better but someone should be able to help on this.
In the early 60s Dave Dozier ran a Chrysler straight eight altered roadster around here. It was a low 12 second car. We sometimes in in the same elimination bracket at Fremont. With the engine in a FED he won the D/D cl*** at the Winternationals one year. Later with a B&M blower on it and in a streamliner of his own construction it went 250 at Bonneville. Dave was very talented. And proved an inline eight will run.
I love this stuff. I have a 1953 Buick 263 waiting to do something cool like this. Keep us up to date when you get started.
If this picture loading works, here's how the car looks today. It's been in the care of Dave Blake for sometime now. He's the guy in the big ole hat on the left. On another note; this big blue lump just happened to be hanging around when I got to work this morning.
I'd be lying if I said I didn't. But that's the life of car ADHD... Posted using my Lil' Orphan Annie Secret Society Decoder Pin
Nick; The 33/34 roadster pictured was in one of the little mags back in the 50's running a Duesenberg engine. That must have been a ride! It reappeared a decade of so later with the Buick, the Duesy having been removed, properly so, for a restoration. This is all from a misfiring of ganglia in my brain, as I can't remember what I had for breakfast this morning.
And then there's this roadster with a Pontiac 8 in it. It's not quite finished yet. He still has to finish putting the front grill sheet metal on it.
Personally I think the proportions of most early Fords could do with a bit of a stretch ahead of the firewall. Raising the axles and fenders relative to the body helps to make the visual improvement effective.
This information is unbelievable guys thank you. Brandon, do you know what the ch***is is on the red roadster?
Someone must have a shot of that twin plug NASH 8 in a Roadster that ran Bonneville in the last 10 years or so. Bob
Just to clarify, The Geronimo roadster never had a Buick engine. It has had a Duesenberg motor since the Ulrich brothers and Andy Granatelli built it back in '47-'48.
Interestingly, though the photo isn't really good enough to tell, the Duesenberg-powered '34 seems to defy the general rule of hot rods having newer parts in place of older parts, in its grille shell as well as its engine. For many reasons I've tended to question the historical universality of that rule. Perhaps it is safer to say that the more sophisticated the context, the less was the tendency to follow the mainstream motor industry's lead.
I'd go with a inline Chevy or Ford Six with a crank driven blower. That will give you your long stretched hood!
Rap rap, I think that is wise advice....unfortunately I have this Buick behemoth taking up all my shed space! The good news is...I have a blower for it...Godfrey K300. But will have to be side drive! Need to think in terms of bigger ch***is than Model A...how about Chrysler G70?
Ed, you are now directly involved, I bought the Rover ch***is. Good thing this is not a Tradit......oh..
Oh cool! It is an amazing frame though! Did it come with a V5? If not finding a Rover 16 logbook shouldn't be difficult, or getting a new V5 for that frame. It'll make registration easier too. Check the regs to see how much Rover you have to keep to avoid SVA. I think that frame will take the Buick. Those underslung frames are easy to build because the engine and transmission sit on top of the frame, not inside it. What body is going on it? Coupe or roadster?
Building a fresh frame out of box section steel isn't as traditional as pulling a cool old factory frame out of a junkyard. Many 1940s rods used oddball frames especially those built for the dry lakes. It's underslung and that makes it so cool. It's a 16hp so I think the rear axle will handle the Buick.
Dawie I could probably recite that thread verbatim! Specials and hotrods run parallel and cross over all down the history line. I do have previous too... Ford A in Frazer Nash ch***is. Vintage hot rod!
