Technical 65 Bel air wagon front springs??
Discussion in 'The Hokey Ass Message Board' started by biggen, May 20, 2014.
  1. biggen
    biggen
    Is there any other spring i can use on my wagon to drop it about 2 inchs Like s-10 or something else? They just don't Make Drop springs for this thing that i can find.
  2. hotrod mike
    hotrod mike
    I got a set of 1" dropped springs for my '67 Vista Cruiser. They were made by BMR. Very nice quality products. You might want to check with them. Good luck.
    biggen likes this.
  3. txturbo
    txturbo
    They make them....problem is....they are 2" drop and that is usually how much the old springs have sagged already. So measure your ride height and compare it to factory specs before you buy them. Eaton Springs makes them. Some people have purchased the drop springs and end up higher than the original sagged springs.
  4. B.A.KING
    B.A.KING
    Eklers late great chevy club. or cut a coil off .
  5. Xtrom
    Xtrom
    from Forman, ND
    I second the cutting of a coil. It's done all the time.
  6. 38Chevy454
    38Chevy454
    Cutting coils is OK if you do not go crazy. Emphasis on cutting, not heating them up to collapse. Just cut and check, you can always cut more but you can't add back. The spring will increase in spring rate slightly, which being lowered is mostly a good thing.
    biggen likes this.
