Really nice, solid 41 Ford. Lots of new parts, runs and drives and stops great. Original 239 Flathead. New parts include: Front and rear posie's springs Front and rear Pete & Jake's shock kits Front Pete & Jake's disc brake kit. Complete wiring harness 12 volt, negative ground generator, battery, cables, solenoid and starter. Holley electric fuel pump, hoses, tank, and regulator. car has only minumal rust which can be repaired before purchase. The only panels it needs are the rear tail pan, p***enger side rocker boxes, front floor, and trunk pans. Quarters, fenders, doors, etc are all completely solid, with no rust. Clean texas ***le, 1941 plates, current tags. drive anywhere. $10k as is, or $15k with rusty panels repaired, and car painted to order. Would consider trades for running driving cars that are similar in value. Can deliver.
