62 Chrysler New Yorker. Pretty solid car. Brought it home as a project. Couldnt get the original 413 to run. Pulled heads off, they need to be redone. pulled out two pistons and the rods dont move freely. Crank has grooves on it. Not sure if crank is any good. The body seems to be pretty decent. Gas tank has been boiled out. It does have bondo by the headlights. Not sure if anywhere else. Throw a good big block in it, go through the brakes and cruise the way it is. Im asking 1600 for it with a clean IL ***le. Its located in freeport, il 61032 Found a car I like better.
Bought a car so I need to sell this asap. Complete car with engine tore apart. Come get it! Brakes work but should probably be gone through. Make offer
