Hi guys long time lurker but this is my first post. I can usually find all the info I need by searching but have had no luck. I have a 52 customline with the running gear out of a 1992 mustang gt. My problem is I need windows for the front driver and p***enger doors. I got a quote from a local guy for 1000.00 installed. Is that outrageous or seem pretty reasonable. I live in Ventura CA. Thanks for the great site.
Welcome from So Cal. It should be a whole lot cheaper than that, I would shop around. Also check out the 52-59 Ford Group. Someone there may know of a good gl*** shop.
That is outrageous! I had some done locally $55 per side for the gl***, removing and installing is very easy to do try these guys for the gl***:http://www.streetrodgl***.com/street-rod-gl***-catalog.jsp Call them.Also do your self a huge favor and get this:http://www.ebay.com/itm/FORD-1952-1...anuals_Literature&hash=item35ab803b65&vxp=mtr and this:http://www.ebay.com/itm/1957-1958-1...anuals_Literature&hash=item3cc498ec8f&vxp=mtr The Ford Parts manual has exploded views of the entire car so you know where everything goes and by looking up the part numbers you can do a Google search for just about anything you need.
I had to have Vent, Door & Quarter window gl*** made for 55' customline 2 door, $230 for all 6 pieces! Plus they mounted lift channels to bottom of windows & mounted gl*** in stainless C channel for vent window! $1000, I'd say that's out of line! Or they didn't want to do it & said an outrageous number like $1000! Just my 2 cents, Jimbo
Or there is this option:http://www.ebay.com/itm/1952-1953-1...r_Truck_Parts_Accessories&hash=item4854bcec7b Not bad for all 6 pieces and your choice of tint, you could message them to get just the two pieces. Also check out these install videos:http://www.youtube.com/results?search_query=cl***ic car door gl***&sm=12
GL*** SHOPS ARE STRANGE. I HAD A WIND SHIELD CUT, AND PUT INTO THE FRAME FOR $95+TAX...I SENT A GUY THERE A YEAR LATER FOR A 32. SAME JOB $200... 3 MONTHS LATER I HAD THEM DO A DOOR GL*** FOR A FORD $40 TO CUT IT AND SMOTH OUT THE EDGES. I HAVE NO IDEA WHY THEY HIT HIM SO HARD.. A DIFFERENT SHOP DID IT FOR $100 MARSHALL....
