Projects Gene (Moonlighter) Cromer's A/G Willys Resurrection
Discussion in 'Traditional Hot Rods' started by Quain Stott, Aug 31, 2012.
  1. rd martin
    rd martin
    from indiana
    havent heard anything lately, sure hope gene can make it to the melt down! looking forward to seeing the car and gene of course!
  2. Pudge87
    Pudge87
    How about as far as HP wise? I understand its a **** shoot, but say with a stock block SBF 500hp is gambling. Just wondering how capable a FE block is.
  3. The cross bolt mains give the 427 some umph, but the bores are thin. Its very common for 427's to have cyl. walls barely.100 thick, on the non thrust side. Before Robert started making his own blocks (the cast iron versions are .250 thick @ 4.375, that's .142 over std) He'd run 4.280 (.047 over, with block filler). The two bolt mains start moving around past the 600HP range and/or high cyl. pressure applications in the 390, 410, 428's from what I'm told. My brother in law Chris Whitney, also races FE's in Stock Eliminator. His best iron head 390 made 496hp, and ram 10.70's @ 124 in F/S @ 3470lbs. He built a legal Edelbrock headed 390 that made 517, then we did some pistons for an Edelbrock 390 Stocker that Lance Line (Pro Stock racer Jason Lines brother)built. I'm not at liberty to say what it made, but it dropped our jaws, and Lances dyno is very conservative. Most good 428 stocker engines make 560-580, Lance's 428's are stouter yet. The 428 guys best bet (before the Pond, or Genesis block), was sleeving down cross bolt 427 blocks. If I were Gene, I'd sell some of his production blocks (they're worth some money), and get a Pond block, it'll take a bunch more steam, however, the production block would take enough steam to put a little more pick up in The Moon Lighters legs. I'm guessing a bit here, but the production cross bolt block might stand 800hp for a bit..,anybody know better?
  4. Frank Taylor
    Frank Taylor
    from Iva, SC
    Think this would help?
  5. Yep, girdles are always better than nothing. My dad had problems keeping the main webs in 265/283 & early 327 blocks. The 3.000 stroke 265/283 cranks didn't have alot of counter weight in them, so when you drop the hammer on one with 60-90 lbs of flywheel, pressure plate, & disc @ 6000+ rpm, the crank would try to "whip" itself out of the mains. Dad first strapped the main caps which helped a little, but the girdle was a big improvement, and adding counter weight to the crank helped even more.
  6. Troublemaker427
    Troublemaker427
    I've been 9.22 @ 143+ at 3350 lbs. with an unfilled '63 center oiler and a flat tappet cam. Those stock blocks can take plenty of power if you build them right... I think we will be faster this fall in killer air with some little changes we recently made too. Mr. Cromer's car runs damn good. It just shows you how good those old FE parts really were. I'm so happy to see that FE out there kicking but and taking names. I'd like to see him put a good C4 in there. We picked up a bunch switching from a C6 to a C4.
  7. OldColt
    OldColt
    I don't know, but Gene ran an FE Wedge in an altered wheelbase mustang circa mid-late sixties, and it ran as low as 8.35 on nitro. That would have been pretty stressful.
    --- Steve ---
  8. Pudge87
    Pudge87
    Has anybody brought up to Mr Cromer how much more he might push the Moonlighter? With the gear change, he must be looking for a little more lol.
  9. Frank Taylor
    Frank Taylor
    from Iva, SC
    Since you mentioned the Mustang, Moonlighter Too. Gene shocked me the other day, while talking about the spool in the Willys. He said that he always ran a open rear in the Mustang. He evidently got it to hook. 149043_1503892242546_7783517_n.jpg
    hendelec and racinman like this.
  10. Some of the Fuel Altereds ran open rears back in the day too, it kept from climbing guard rails.
  11. Pudge87
    Pudge87
    I've often wondered what ever happened to that Moonlighter.
  12. s55mercury66
    s55mercury66
    from SW Wyoming
    I think running an open rear end was more common back then, than we think. This is a really great story, and a really good thread. Still my favorite.
  13. Frank Taylor
    Frank Taylor
    from Iva, SC
    The Moonlighter still wows the fans, 5/31 @ Shady Side Dragway.
    hendelec, FlynBrian and s55mercury66 like this.
  14. Bean Dip
    Bean Dip
  15. bgas56
    bgas56
    An instant cl***ic shot!
  16. HOTRODPRIMER
    HOTRODPRIMER
    Every time I see the wheels of the Moonlighter in the air I am so thankful to everyone that help Gene get back behind the wheel.
    I remember a few people ask me did I think Gene was going to race the car or just do some exhibition runs,,,I think even the naysayers have now become believers.
    I knew Gene was still a racer at heart but I believe with all my heart he has exceeded his own expectations,,he was my hero when I was a kid,,he still is! HRP
    FlynBrian and Bad Banana like this.
  17. sbs
    sbs
    Amen to Gene being a hero for his racing abilities and the type man he is when not behind the wheel of that iconic Willys. Behind a great man is a great lady-always! Ruth!
    Frank Taylor likes this.
  18. Frank Taylor
    Frank Taylor
    from Iva, SC
  19. Frank Taylor
    Frank Taylor
    from Iva, SC
    This video is what the South East G***ers ***ociation is all about.
    Austin Bubbletop likes this.
  20. HOTRODPRIMER
    HOTRODPRIMER
    Thanks for posting Frank and a big thanks to the guys at skull garage for the great video. HRP
  21. Gene Cromer
    Gene Cromer
    Anyone wanting shirts pm. me and give me your mailing address, size and the blue or black color.
    Gene,
  22. 1956 F100
    1956 F100
    from Louisiana
    Gene
    I sent a PM to you about a t shirt. Gary
  23. Quain Stott
    Quain Stott
    Just dropping in to say hi because I haven't been here for a while. The new hamb setup had quit letting me know there had been stuff posted on here so I hadn't stopped by. As y'all can see by the videos Gene has been running the wheels off the Moonlighter. On my way in I checked, this thread is over 375,000 views Thank's for all y'alls support.
    hendelec likes this.
  24. pontman
    pontman
    Gene, I sent a message also, they are conversations now?
  25. OahuEli
    OahuEli
    from Hawaii
    Man, i
    Its comments like this that are music to my ears (eyes?). Too often, old farts like me tend to miss the fact that technology has come a long way since we were youngun's. The fact that we can combine the best of the old and new, using state of the art materials while preserving the visual points of the older engines is just a win-win situation. I'm a diehard carburetor and points guy but if the newer material available makes my engines better I'm all for it.
  26. OahuEli
    OahuEli
    from Hawaii
    Btw I just watched that video that Frank Taylor posted and got a kick out of that '57 Chevy treeing the hell out of Quain. Maybe he was on his lunch break. lol
  27. TomP64
    TomP64
    from Vancouver
    You guys really do g***ers right! That looks like a great series. Gene's is very cool being a Ford 427.
  28. Frank Taylor
    Frank Taylor
    from Iva, SC
    The guy in the 57, Dale Wilson, is the real deal. He works on his own car in the back yard, no shop, and is happy to be on the track with the South East G***ers. While some of the guys are spending big bucks trying to get into the 5's, Dale is just hoping to break into the 7's. I wish there were more like him.
  29. Quain Stott
    Quain Stott
  30. Frank Taylor
    Frank Taylor
    from Iva, SC
    The Moonlighter is going to be at the Day B4 Father's Day car show in downtown Anderson, SC tomorrow. Come on out and see the Moonlighter and a whole bunch of other great looking cars.
    Quain Stott likes this.
