Projects Drug home this Henry J project.....
Discussion in 'The Hokey Ass Message Board' started by Littleman, Oct 18, 2013.
  1. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    The main 1-5/8'' .083 chromoly hoop is bent up....just need to cut for the overall top to bottom....
    Baron likes this.
  2. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Started to make one of the side bars......close to fit.....then onto the drivers side....
    Baron likes this.
  3. Babyearl
    Babyearl
    That sure looks like a nice tight fit,, on the side bar.
  4. Cadmsobile
    Cadmsobile
    What width is your axle housing? I'm planning on using an 8 3/4 under my Henry J. I found a cheap B-body housing that seems like it might fit OK. Nice Henry!
  5. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    The housing is factory width......just a little bit over 52'' from housing flange to flange.........Littleman
  6. 51 Hemi J
    51 Hemi J
    Any new updates Littleman? I always look forward to your build updates! Impeccable Work!
  7. racer_dave
    racer_dave
    That's a pretty wide axle. Do you have a plan to keep all the welding heat on the back side of the housing from changing the toe of the rear axle? Or is it simply a matter of making some 1" tacks, check it and then finish it up?
  8. dana barlow
    dana barlow
    from Miami Fla.
    I still love "J"s had one my self back in the early 1960s I a lot of mods too,enjoy seeing what your doing to your.
  9. mad mikey
    mad mikey
    Looks just GREAT. You are a true master sir. Mikey.
  10. Hdonlybob
    Hdonlybob
    Now that is a really nice project..
    Good luck..
  11. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    The housing is fully welded and good to go........I did not strap it down or strap and preload......It took me a few days 1'' at a time and weld placement....It was checked before and after. The finished pics are in this thread....Dave
    Baron likes this.
  12. Nice progress Dave.
  13. D-man313
    D-man313
    I always like reading through your threads. Another good job!
  14. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Engine set back perspective with the front clip mocked up....
    You do not see the cage from the side view...
    I lowered the cage and squirted the top of the cage hammertone blue before welding into place..
    Baron likes this.
  15. 41 Dave
    41 Dave
    Littleman, Better plan some stout wheelie bars ! That Henry will sure be one mean "J" ! Sure hope you post some great video .
    Dave
  16. enloe
    enloe
    from east , tn.
    UPDATES???????
  17. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    003 (1024x576).jpg 002 (576x1024).jpg 015 (1024x576).jpg I have some of the floor structure bent up and tacked in........it will all be connected to the roll cage......
    Baron likes this.
  18. careyohio
    careyohio
    Dave....You are one of the finest craftsmen I have ever known.....and I still want to be just like you when I grow up !!!
  19. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Was able to push the Henry out today for the first time..........Started to figure out the firewall as well..very productive weekend....
    Baron likes this.
  20. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Carey, you are way too kind..........you know me.....just another back yard rum-cake............and that is ok..........
  21. mad mikey
    mad mikey
    WOWWWWWW!!! The J is outstanding!! Have a great memorial day littleman!
  22. Inland empire hot rods
    from so cal
    Love the new project!!!
  23. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
  24. peter schmidt
    peter schmidt
    from maryland
    Wow can't wait to see a video of this car running down the strip! Great craftsmanship
  25. bartmcneill
    bartmcneill
    from Ada, OK
    Nice, I have a Sears located. Just waiting for the right time. Sears was a Henry J sold by Sears for anyone that did not know like I didn't before finding this one.
  26. alumslot
    alumslot
    That would be called an Allstate. Still a rare car for sure.
    Jim
  27. derbydad276
    derbydad276
  28. In the mid-fifties, we had upgraded to a '52 Henry J from the '41 Pontiac Torpedo in my avatar. No trunk, but it was a neat family car. In my mind, I'm juxtaposing Mom in your updated Henry J. Hilarious visual! Thanks for the mind flip.
  29. Gizzy
    Gizzy
    from N.W,Ohio
    This thing is so cool.....;)
  30. Chaz
    Chaz
