Hi guys, Swapped a standard transmission in my Vic and I need the clutch release equalizer bracket bolted on the side of the engine, part number B2A 7509-B. I have all other parts in hand except this bracket! Please, let me know if you can help me! I don't want to put hydraulic stuff on my car!! Thanks!
Or worst case, if someone can show me some good pictures with measurements I will be able to make this bracket... But, of course, I prefer to buy one!
I have one that came off my 53 flathead when I did my T5 swap if it will work. Let me look and see if I can find it
Sure I'm interested! Let me know if you find it... But, I'm curious to know how you modified your clutch linkage if you don't use this bracket! You installed a hydraulic master and slave? Thanks!
Go over to the '54 Ford Club of America and post it in the wanted section..I'm pretty sure Alan Freeman will probably have what you need. HRP
Ok, I just remembered, I can not post on 1954ford because my account has never been activated by the admins!!
