Technical Welding Help
Discussion in 'The Hokey Ass Message Board' started by Dickj42, May 27, 2014.
  1. Dickj42
    Dickj42
    from East Texas
    I'm welding up a bunch of old header pipes to make a header that will fit. I cut the pieces, tack them with MiG, and then do the final welding with gas. Some of the welds (most of them) look like **** - I only weld stuff about once every eight to ten years. Can I "dress" these welds by br*** brazing over them?
    **** J
  2. jlaird
    jlaird
    ****, are the header pipes just plain mild steel? Can you post some pictures?
  3. squirrel
    You'd be better off spending some time practicing welding spare s**** tube segments together, till you get the hang of it. It's not that hard, I just made my first set of headers, doing the same thing--fit the tubes well, tacked them with the mig in 3 places. ground down the tack welds, then welded them with the torch. Fit is important. Clean bare metal welds better than rusty dirty metal, too. Sand the **** off the ends first.
  4. Koz
    Koz
    Agreed with above. If they are a bit ****py you might want to clean the welding areas with a satainless brush and MIG them using a string of "tacks". This may work a bit better using straight Argon but the Argon/CO2 mix will be fine. Sandy Belond, the original header builder used to dress his headers with br*** and they looked and survived great. There are a bunch of threads on here that show it done and here's some I built a while back, MIG and gas.
    http://s861.photobucket.com/user/larrykoz1/media/NEED TO BE SORTED/100_0476.jpg.html
  5. jlaird
    jlaird
    Also agree with the above. Tack them with about 1/16" space so you get good penetration.(***uming your are MIG welding) Then do s***ch welds...hit the trigger about 5 times or about a quarter of the cir***ference of the tube. Finish the welds with an angle die grinder and about a 40 grit disc just before you hit the parent metal, then finish with about an 80 grit. If you want to get crazy, you can file them as the last step. Good luck!
  6. 270dodge
    270dodge
    from Ohio
    If you add the br*** it might work but that will interfere with future welding with MIG or TIG or stick.
    The br*** must be removed to use other forms of welding.
  7. squirrel
    I try to get a gap about half the thickness of the metal, when welding with a torch. This is what my first header looked like. I brazed the tubes to the flange, and gas welded the tube segments, and the collector.
  8. fatkoop
    fatkoop
    I would not braze over the gas welds. Its not very strong, and will most likely crack and prevent any future weld repairs. Practice on some s**** tubing, using good welding rod. Clean the joint well and get a good neutral flame. Use a small tip, like a 0, shouldn't need more than that with exhaust tubing.
  9. snaptwo
    snaptwo
  10. snaptwo
    snaptwo
    Practice, practice,practice , 00 tip neutral flame clean material , no gap and no filler(maybe a touch but not much) !
  11. flt-blk
    flt-blk
    from IL
    Im with Snaptwo. No gap and little to no filler. Working on a set of headers for my S2D. I tacked with the torch in 2-3 spots then welded it, no mig at all. Clean Clean Clean on the metal
    metal [​IMG]
    and I brazed a fillet on the flanges too, this should prevent any cracking and remove the need to repair.
  12. banginona40
    banginona40
  13. Ole don
    Ole don
    If you have rusty metal, run it across a wire brush on the bench grnder. If you have new metal with a galvanized coating, do the same hard enough to remove the galvanizing in th elast 1/2 inch. Fit th etwo together and tack in two or three places, then gas weld with no filler. Contrary to what one guy above said about br***, a good braze is about a 60,000 pound connection, or the same as a fair gas weld. For filling little holes, and adding stregth, brazing is good. Hard to paint over though. Furnace brazing looks glorious on headers.
  14. flt-blk
    flt-blk
    from IL
    And don't forget to pinch and weld the tube ends before welding on the collectors.
  15. squirrel
    **** welding with a torch with no gap doesn't guarantee that you'll get full penetration with the weld. I guess it's ok on headers, there's not much load on the tubes. Just something to consider.
  16. Canuck
    Canuck
    Question for those that are re-enforcing the weld on the flange with braze on the outside --- How do you avoid any warpage to the flange?
    Have Sanderson headers that are welded on the inside leaving a gap all around the outside, but they use a machined weld bead on the inside for sealing.
    Canuck
  17. squirrel
    I clamped mine to the 1/4" steel plate topped work bench before brazing. There is a slight amount of warpage in the flange that pulls flat when bolted to the head. Less than .030"
  18. 38Chevy454
    38Chevy454
    Also, since you are using old header tubes, make sure to clean the inside as well as the outside around the weld areas. Wire brush is good way to clean, and ensure no contamination.
  19. dreracecar
    dreracecar
    from so-cal
    because brazing is done at a much lower heat, you are not getting into the parent metal as much as juts useing extreem heat to get the br*** to stick---hard soldering
  20. 49ratfink
    49ratfink
    what does brazing over a weld do? never heard of that.
  21. squirrel
    I think it fills in the holes so it doesn't leak.
  22. tommy
    tommy
    I like to go over my Mig welds with just the torch creating a puddle that I can control. You might be surprised at how you can clean up a weld after it is made. Mig welding is a function of wire feed and heat. Once it is welded together you can control the heat and the speed with a torch getting a consistent puddle which gives you a consistent pretty weld. Is that cheating?
    We had a few artisans that could make art out of a weld. One local guy was famous. I don't like br***. It's just my personal preference. It's quick and easy but I'm an elitist I guess.:rolleyes:
    racingonerobb likes this.
  23. 49ratfink
    49ratfink
    that must be why I've never heard of it.
  24. alchemy
    alchemy
    If you've got a hole, you just need more weld.;)
    Seriously, I think lack of cleanliness is the cause of 99% of welding problems.
  25. squirrel
    So poor fitment is only 1%? I'd give it more than that
  26. 26 T Ford RPU
    26 T Ford RPU
    I don't leave a gap as if you do put a bit of s**** to space it ,it will most likely get clamped in there. Instead just chamfer the ends to get the weld to penetrate. As for the brazing.. DONT ! as every time it gets very hot the br*** penetrates more and cuts through the steel, cracks and falls apart. JW
  27. Blue One
    Blue One
    from Alberta
    I'm left wondering after this what percentage can we give to just plain lack of skill :confused: :D
  28. Deuce Daddy Don
    Deuce Daddy Don
    Forget all that brazing, just stick with parent metals, & use fusion on the tubes.
  29. kelzweld
    kelzweld
    Lots of different ideas here... My take... We're talking tube here, not pipe, so I'd go for a closed **** (no root gap), and wouldn't bother with any bevelling, and if you know what you're doing 100% penetration is obtainable. I'd also be using filler wire as I feel a little weld reinforcement is a good thing. At the flange joint, I'd weld the inside with mild steel wire, and braze the outside, once again for reinforcement. This is how I've just done my headers (which are the last entry on my build thread), except I tigged them instead of gas welding. No real difference though with the process for headers in my opinion.
  30. gary terhaar
    gary terhaar
    from oakdale ny
    On hi-end headers and custom ones I have seen and done the flanges are silicone bronze welded. This keeps the tubes from cracking at the flange.
    A little tip thought to me by George kook sr. Of kooks headers
