Hot Rods Lower radiator hose, spring, no spring
Discussion in 'The Hokey Ass Message Board' started by st.rod, May 31, 2014.
  1. st.rod
    st.rod
    Howdy,
    Time to replace radiator hoses. Built the car about 20 years ago. The lower hose that I used had no spring so I put one in from another hose I had.
    Is it necessary to have that before I ****on this up?
    Larry
  2. Ulu
    Ulu
    from CenCal
    It's a good idea, so that coolant can be recovered from the overflow. Otherwise, the hose can collapse flat under the vacuum.
  3. Hemi j
    Hemi j
    from Colorado
    What Ulu said !!
  4. st.rod
    st.rod
    Don't have an overflow. But might as well put them back in...
    Thanks
    Larry
  5. Ulu
    Ulu
    from CenCal
    I always run an overflow (coolant recovery) tank, because Prestone is like $9 now, plus I hate the stuff spewing on the ground.
    If you've ever come up to a stoplight on a motorcycle and put your foot down into a puddle of someone's hot Prestone, you'll understand.
  6. tommy
    tommy
    I don't think I ever had a lower hose with a spring. Personally I don't think that it is critical. But I'm a dare devil and always press my luck. I know that some have springs but in 50 years I've never needed one. Your mileage may vary.
  7. chopped
    chopped
    Newer hoses are made different, some don't need a spring.
  8. Ulu
    Ulu
    from CenCal
    Some coolant systems aren't pressurized & don't need a spring IMO if there's no overflow recovery bottle.
    Also, hoses get soft. A new hose which is short will likely never miss the spring.
  9. ZAPPER68
    ZAPPER68
    from BC
    Put the spring in the lower hose...better to be safe than sorry when it collapses down the road in the middel of nowhere....
  10. 26 T Ford RPU
    26 T Ford RPU
    If doesn't mater if its pressurized or not it can still collapse, newer hoses are more flexible and more likely to collapse causing restriction. Put it in and happy motoring. JW
  11. yruhot
    yruhot
    When I was young, we had a friend with a old chevy blazer the would run around town just fine but get it on the freeway and it would just boil right over. Put it on the rack and revved it up and you could just see the lower hose **** together and starve the water pump for water. New hose with spring and problem solved. I would highly recommend a spring type hose just to be safe. in my humble opinion.Doug,yruhot
  12. Da Tinman
    Da Tinman
    Having a spring and not needing it wont hurt near as bad as not having a spring and needing one.
    I say the same thing about firearms too.
  13. BamaMav
    BamaMav
    from Berry, AL
    Yep, any water pump is capable of ****ing the lower hose shut like that. A spring is just good insurance that it won't happen.
  14. Ulu
    Ulu
    from CenCal
    When one collapses, if I open the radiator cap & it'll expand, because the system was closed & trying to **** a vacuum. An open system shouldn't do that, should it?
    I always run a spring, but I always run a closed, pressurized system...
  15. 26 T Ford RPU
    26 T Ford RPU
    It may be pressurized but when the water pump is earning its keep at mid/ higher RPM there is a lot of resistance for the coolant to flow, that's when the hose will collapse.......when its needed most. JW
  16. tfeverfred
    tfeverfred
    I got tired of popping my radiator cap, even though it was infrequent. Best thing I ever did was to install a spring. It costs damn near nothing to do and the benefit is worth it.
  17. Engine man
    Engine man
    from Wisconsin
    I agree, same with money!
  18. Ulu
    Ulu
    from CenCal
    Yeah, you are right. Why do I have a blind spot about this spring thing?
  19. stimpy
    stimpy
    on tight curved ones was either a spring inside or a solid pipe like we do on the semis only use the rubber as a short connector and the metal also helps disapate some heat too .
