47 ford coe (car hauler project)
Discussion in 'The Antiquated' started by corvettesander, Dec 25, 2012.
  1. olcarguy
    olcarguy
    That ****s. Call it tuition. Learn for next time.
  2. Mart
    Mart
    Sorry to hear about you engine problems. The truck looks fantastic.
    Mart.
  3. here some pics of the damage ....
    now looking for a rebuild kit + a new crankshaft.
    i could go for a re grind, but for the same money i can order a new one
  4. Buddy Palumbo
    Buddy Palumbo
    Damn - that ****s !!
  5. You don't show the bearings,but that doesn't look like thin oil damage, it looks like dirt in the oil. Gas contaminated oil would scuff the bearing surfaces evenly, yours are only scuffed at the oil hole.
    Doesn't matter though, it always ****s to lose a new engine!
  6. Wrong! 4bt ***mins it what it should have, after all it is a TRUCK not a car!:p
    But it is a *****en ride!!:D
  7. vintagehotrods
    vintagehotrods
  8. took the engine totaly apart today
    inspected and cleaned all the parts
    the cam shaft did not got damaged :)
    just ordered the needed parts.
    rebuild crankshaft, rod, main and cam bearings,
    oil pump, pistons & rings timing set and full gasket set
    now sit back and wait :cool: for it to arrive :rolleyes:
  9. dropped53
    dropped53
    from Hanford CA
    Beautiful truck, you sir are very talented, enjoyed reading this thread
  10. Scumdog
    Scumdog
    I once without realising it ran a 272 Ford with about 2 gallons of gasoline mixed with the oil in the sump.(Long story involving trying to tow-start the F100 for a couple of miles -and the float in the carby being stuck down)
    After dumping the oil-fuel mix and puting new oil in (never thought to change the filter...:rolleyes:) it ran for years with no problems.
  11. castirondude
    castirondude
    i'm surprised that the gas would do so much damage, usually as long as there is something flowing through it will be a while before there is damage
    Sent from my DROID4 using Tapatalk
  12. castirondude
    castirondude
    man such a sinking feeling though to take stuff apart again. when i built my car it didnt leave the shop without mechanical oil pressure & coolant+trans temp gauge
  13. at the first start up i checked and had oil pressure,
    i am not sure its caused by the fuel,
    it could also be that the damage started way earlier
  14. v8steel
    v8steel
    Sander - You bring up a good point. Did you get the engine from a reliable source? Did it seem like a good deal? Is it possible someone sold you that engine with the damage already started?
    Still an awesome build! Good luck !!!
  15. Brand Apart
    Brand Apart
    from Roswell GA
    It's hard to say what caused it. Those are great engines but there are so many of them made there is bound to be failures.
    I am in GMC and Chevy dealers once a week and there are always some torn down.
    Friday I was talking with a tech who is rebuilding a LS7 (those are originally hand built in a seperate GM facilityand signed by the builder) the engine in question only has 5,000 miles on it they pulled it apart for a noise, found no evidence of the cause re-placed the bearings that did not fix the noise so now they are replacing just about everything.
    sometimes there is no explanation. your truck is still the best thing on here hands down.
  16. ok some update on the engine rebuild
    yesterday 99% of the parts arrived from the states.
    got a remanufactured crankshaft (as it was cheaper and faster )
    and
    new main, rod and cam bearings
    pistons and rings
    oil pump
    timing set
    full gasket set
    only waiting for new cilinder head bolts
    already got the crank , cam and pistons in place
    honed the cilinder bores
    and installed the pistons
  17. kscarguy
    kscarguy
    Are you going to replace the oil pump...just in case?
  18. Yes i did . i didnt want to take the risk in not replacing it . And discover it was The or one off the causes
    And its in a not so easy accesable location as wel
  19. oldcarguygazok
    oldcarguygazok
    from AUSTRALIA.
    Fingers crossed this time,good luck,Gaz!
  20. JOYFLEA
    JOYFLEA
    No problem for Supper man , fast as a speeding bullet !
  21. intalled the engine without heads first and lowered the Coe back on the Ground
    and then installed heads ,intake and the rest of the stuff,
    and got the engine running again (now including oil pressure :)).
    then my Dad has been creative and added some text to the sides
    slychamp likes this.
  22. joco
    joco
    great that the v8 is running again
  23. kscarguy
    kscarguy
    "anywhere"...hmmmm?
    Does that include Kansas?
  24. No problem Mike !
  25. Corvettesander, if you get off the boat in New York headed for Kansas, a little side trip to Wisconsin wouldn't be very far out of your way. LOL
  26. redzula
    redzula
    I'm thinking personal visits to everyone watching this build in the states haha. Iowa is between Wisconsin and Kansas lol
  27. JOYFLEA
    JOYFLEA
    Texas ain't too far .?
  28. racer_dave
    racer_dave
    Well, to get from NY to Wisconsin you have to go through Michigan. I have beer!
  29. Fasttoys
    Fasttoys
    And while your on the road swing by China also. OK, maybe you will need a boat too. LOL
  30. took it to the first show yesterday :)
    OahuEli, daddio211, slychamp and 2 others like this.
