Technical Body to frame bolt location
Discussion in 'Traditional Hot Rods' started by krowbar, May 31, 2014.
  1. krowbar
    krowbar
    from michigan
    Trying to locate all the bolt locations to bolt my body to the frame on a 1939 Ford coupe. I have new rails as well as a new floor. I bought a bolt kit and it has over 100 pieces. When I removed the body 7 years ago I don't remember where all the locations are today. What I do see is 10 locations plus the transmission cover that has 4. I do know that there are mounts that did not have bolts go through them, like the ones that go around the outer sub rail. I do remember there no holes in the old sub rails. I'm wondering if some of the bolts secure other front end pieces I haven't gotten to yet. Lemme know, if there is a diagram available, or your experience......Marshall
  2. 19Fordy
    19Fordy
    This is from an old BOB DRAKE Catalog. 1937-40 Ford. Might help.
  3. Russco
    Russco
    from Central IL
    That about covers it, I just did my '40 by that same Bolt/pad kit and drawing and I think I had 4 left over
  4. Mart
    Mart
    All the body bolts on a 40 go in from the top unlike a 33/34 which have some going in from the side. The two mounts behind the rear crossmember have the long bolts.
    Mart.
  5. mgtstumpy
    mgtstumpy
  6. joel
    joel
    009.JPG 007.JPG 006.JPG here are several pix of my 40 floor with pieces of tape by the holes that are body mounts.I count 10 per side.
      206.2 KB
      114.3 KB
  7. krowbar
    krowbar
    from michigan
    We're some of the bolts in the kit for the running boards? And, about
    how many bolts do you have that actually secure the body to the frame small pick up?
  8. krowbar
    krowbar
    from michigan
    It could, I think I will copy and enlarge, very nice, thank you.
  9. krowbar
    krowbar
    from michigan
    10/4 on the holes. I have the same marked and going toward the rear I have 2 more on the trunk floor an 2 in the tool tray. Is that a trunk shot in the 5th pic. Thank you
  10. krowbar
    krowbar
    from michigan
  11. krowbar
    krowbar
    from michigan
  12. krowbar
    krowbar
    from michigan
    Thank you
  13. joel
    joel
    Yes, there are 2 in the tool tray area; they are where the corner braces from the trunk seal lip fasten to the forward wall of the tool tray. The other 2 in the trunk area are where the channel under the trunk floor is located. There is a "wedge shaped piece" on the underside of the upper lip of the frame where the body bolt goes.
  14. joel
    joel
