Projects 1954 Lincoln Capri.....a car with a small history
Discussion in 'The Hokey Ass Message Board' started by derthor, Jan 12, 2014.
  1. derthor
    derthor
    from Germany
    Sounds very good. .....where are the pictures ;) 54 Lincolns are very rare and here in Germany I think I have the only 4door sedan :D
  2. derthor
    derthor
    from Germany
    the new stance
    before
    after
    brEad and Ranchero59 like this.
  3. derthor
    derthor
    from Germany
    wiring grows up step by step
    instruments are done
    wiring for the right hedflight and flasher are also done
    headlights are done
  4. derthor
    derthor
    from Germany
    the old lady grows up step by step
    got new ventilation grills
    for adapting work times I mounted both fenders
    I think the stance looks good
    Ranchero59 likes this.
  5. Helge71
    Helge71
    They are rare over here...especially as 4 doors. I have a 2 door where i am only starting the work you already progressed so far... Mine is an old race car an will be brought back to functional Panamericana style...wish I was as advanced with the project as you are...
  6. derthor
    derthor
    from Germany
    the valve cover gaskets, I bought last year have been a little bit to short (10cm) so I had no other chance than cutting new once by myself
    heat protection for the crossover tube
    the new cables are in place, now it´s time put them right into the fuse box.....a lot of work but I think that´s the right way
    weiter gehts dann hoffentlich am kommenden Freitag :D
  7. derthor
    derthor
    from Germany
    the battery will get his new home in the trunk, for that I built a battery holder
    philedealer likes this.
  8. drtrcrV-8
    drtrcrV-8
    I noticed the original vacuum wiper motor: now that you've changed to 12volt electrics, you might consider changing to electric wipers for reliability. Many years ago (same problem) I unbolted the vacuum motor , bolted on a 1956 chevrolet electric wiper motor (mounting screws & linkage connection are the same), attached the Lincoln control cable, attached the wiper motor power-wire to the electrical system. Result : reliable wipers operated from the original control on the dashboard. Other vehicles may have the same wiper motor. I hope this helps.
    brEad likes this.
  9. derthor
    derthor
    from Germany
    THX for that!! :D That sounds good, I think I have to look for one ;-)
    GreenGrenade likes this.
  10. derthor
    derthor
    from Germany
    Hi @all I have a question to the "Lincoln Guru´s" here at the HAMB. I´m searching for dropped spindels for my `54. Does anyone of you know where to find them??? A little bit longer ago I found some pictures of a customized `54 that had some dropped spindels and disk brakes. At the moment I´m collecting the parts for the disk brakes. I´ll use E-150 disks and 99 Camaro callipers.
    If I´m wright, this `54 has the dropped spindels. Maybe some of you know this car and can help me to get contact to the owner ???
  11. Wow. She taught school in my town. Ellensburg, Wa
  12. chopolds
    chopolds
    from howell, nj
    I think that's Rob and Debbie Butler's Lincoln. She used to be here on the HAMB, under LincolnLady, or similar name.
  13. derthor
    derthor
    from Germany
    time to start frenching the antenna
    couldn´t get it finished at that evening .....but I´ll do that in the next days :D
  14. derthor
    derthor
    from Germany
    played once again with the hight and now I think it looks good...2,5 inches are enough
    next thing to do is closing the fender skirts, I´m waiting for mine that I will get in the next few days
  15. derthor
    derthor
    from Germany
    glovebox with radio :D
    first idea sketched with Inventor
    the laser cutted parts
    chryslerfan55 and 54LincCapri like this.
  16. derthor
    derthor
    from Germany
    building the exhaust system
  17. JoeyP.
    JoeyP.
    Cool project
  18. Lebowski
    Lebowski
    Nice job on the restoration. I had one identical to yours a couple of years ago. Keep up the good work....
  19. Still watching. Wish mine had front fender air ducts as nice as yours.
    I bought a '57 368 out of an original car with A/T attached. It's the Ford not GM ******.
    I would've gone with '55 exhaust manifolds to eliminate the crossover and get duals. Fortunately the '57 engine came with those manifolds, 12v starter & generator, spin-on oil filter, Carter carb and a paper element air filter with a fresh air duct to the radiator header.
    I found a Mexican VIN tagged '55 Lincoln. It has heater delete pieces. I might have to see if I can get those in the future. How it landed on the east coast of USA baffles me. It's a rusty piece of junk.
  20. derthor
    derthor
    from Germany
    chryslerfan55 and prez like this.
  21. 54LincCapri
    54LincCapri
    from Walnut CA
    Awesome job! Thanks for sharing, great motivation. Keep up the good work.
  22. U-235
    U-235
    Love the work your doing, those valve covers and air cleaner are great. I like the stance and the mods to the fenderskirts. One thing tho, and its just my opion, but the wheel combination (painted w/spiders) just doesn't go with the stately Linclon. Choose a nice set of wheel covers instead. You have the ability to phtochop.....try it.
  23. coolbreeze1340
    coolbreeze1340
    from Indiana
    I'll be following this one.
  24. I'd like to see some updates on this project. Especially interested in the wiring.
    As for the disc brakes. I'd try some Carbon/Kevlar friction material on those stock 12" dia. shoes before I went to all that trouble. Try Porterfield Brakes, they are on the west coast, OR or WA. I told one of my buds about them. He tried their stuff and it works.
    I latched onto a BIG JOB Rated Ford truck intake manifold from a HAMBer. It'll accept the dual float Holley with no adapter plate and bolt right on any of these Lincoln Y-blocks.
    I've also located a truck bell housing, flywheel that'll bolt on the Lincoln engine. Just might have to make mine a 4-speed!!!
    AND I bought another '54 Lincoln 2-dr hardtop. Have to go pick it up. It's about two hours away.
  25. karlssons
    karlssons
    from sweden
    Thumbs up!
    I also have a 4-door mild kustom.
  26. coolbreeze1340
    coolbreeze1340
    from Indiana
    On an earlier post I seen you rebuilt your front end. Did you replace the ball joints? If so, where did you get them???
    Thanks in advance
  27. derthor
    derthor
    from Germany
    Hi coolbreezel, no I didn´t replaced the ball joints ´cause I found them at ebay.com and they were "a little bit" to expencive and mine looked good.
    http://www.ebay.com/itm/Remanufactu...ash=item5b33f5e057:g:36sAAOSwTuJYr5uF&vxp=mtr
    http://www.ebay.com/itm/Remanufactu...ash=item544369a4ed:g:mTgAAOSwTM5YtkZe&vxp=mtr
  28. So, that's just over $1,000 for just ball joints! OUCH!! All the more reason to do the screw in Chrysler screw in ball joint conversion.
    Still not cheap, but here's Kanter's complete front end kit: https://www.kanter.com/productdetai...&CategoryID=39&ProductCode=182&Router=Catalog
  29. coolbreeze1340
    coolbreeze1340
    from Indiana
  30. derthor
    derthor
    from Germany
    Long time ago since my last post and by the way.....I was a little bit "tired" and not so many things happened to the old lady. I moved to another place with the Lincoln and I only made some small things. I frenched the antenna, built the fender skirts, stripped the paint of the fenders, hood and the trunk and got new plans for the steering, the brakes and the exhaust
    startet with the fender skirts
    brEad, Ranchero59 and chryslerfan55 like this.
