Projects Model A frame almost finished
Discussion in 'Traditional Hot Rods' started by 46Chief, Jun 10, 2014.
  1. 46Chief
    46Chief
    I put this Model A frame together to go under my 30 coupe. Logan Davis and Chuck of Vintage Performance Automotive in Santa Clarita CA did all the dialing in final welding and came up with a cool way to mount the T-5 buy hanging it from above. Jeff Jones aka "Nailhead Jeff" built the flathead. Mostly old Ford parts with a few modern add-ons.
    48fordnut and patmanta like this.
  2. HOTRODPRIMER
    HOTRODPRIMER
    Looks great,the T-5 hanger is unique. HRP
    46Chief likes this.
  3. 46Chief
    46Chief
    Thanks HRP, the hanger clears up the side view. The only visible cross member is the wishbone ball mount.
  4. Texas Webb
    Texas Webb
    Would like to see a close up on the wishbone ball mount,and that's a clean T-5 mount.
  5. oj
    oj
    Very nice ch***is and workmanship, what spindle is that?
  6. Dreddybear
    Dreddybear
    Some real cool stuff going on there.
  7. 46Chief
    46Chief
    Thanks All
    The ball mount crossmember is just a Ford AA truck that's been cut and bent to fit. The spindles are 32 along with the axle (Thanks 296 V8) and the arms were set up by Dennis Lacy to work with the drop.
  8. 61falcon
    61falcon
    how difficult will it be to remove the trans with the body on?
  9. 46Chief
    46Chief
    To remove engine/trans with body on, the top two bolts on the Transmission top come out leaving the hanging crossmember with cushions in place. Also the brake pedal cross linkage can unbolt to allow for more swinging space. Logan Davis takes servicing the car into account when he's doing his fabrication work. He changed more than a few things that I had made. Can't say enough about his workmanship and ability.
  10. 46Chief
    46Chief
    Here's the pedal cross linkage set up which is removeable.
    Texas Webb likes this.
  11. Texas Webb
    Texas Webb
    Thanx,46Chief.That's a clean professional install.
  12. HOTRODPRIMER
    HOTRODPRIMER
    You got that right! HRP
  13. Panel Pete
    Panel Pete
    Nice setup, clean and well thought out. Care to share the details regarding connecting the T5 to torque the tube drive line - home brewed or was it a kit? How difficult was it to install?
  14. 46Chief
    46Chief
    T5 to Torque is one of CrazyDaddyO's adapters. It is very well engineered and made and is a breeze to put together. Torque Tube/axle had to be shortened but the Lincoln Radius Arms were almost a direct bolt on. I used Dwight Bond's adapter for the flathead to T5. Another really well made and designed part.
  15. 35 Dodge Hot Rod
    35 Dodge Hot Rod
    from Mecca
    Do you have any more pictures of the front wishbone mounts and just of the frame in general? Any side pictures? I think you nailed it perfectly.
  16. pitman
    pitman
    Gorgeous work! Much appreciate the pics.
  17. sko_ford
    sko_ford
  18. 46Chief
    46Chief
    Here's a close up of the wishbone mount. It started out as a AA center crossmember which was cut down, heated, bent, hammered, welded and was made so it could be unbolted. image.jpg image.jpg
    48fordnut and Texas Webb like this.
  19. Texas Webb
    Texas Webb
    Thanx again.
  20. Uptown83
    Uptown83
    Nice! So is that a 4x4 s10 t5? Wanting to do the same setup but on a 33
  21. 46Chief
    46Chief
    Yes Sir, 4x4 s10 I think 1986 model but don't quote me...I tried to figure out a way to move the shifter forward about 8 inches as that's where it would be with a Ford 3 speed. Right now it will be just in front of the seat.
  22. Mr48chev
    That is some nice work. This one is going into my A V8 reference file.
  23. King Callie
    King Callie
    from Virginia
    I really like this build! I will definitely be considering that t-5 mount for my own project. Thanks for sharing!
