I have an interest in owning a 39 chevy coupe, and would like to hear from some one that has one. What supension? Did you use a clip? Parts sources? I hope to find a running driving car.
just finished a 37 coupe. Same frame I guess. We used a JW Hotrod front end and Ch***is Engineering rear set up. Nothing fancy just a good driver and safe for the owner who wanted it that way but not very traditional. He had us remove the straight axle as it looked to much like a g***er he thought!
Thanks. That is my opinion also. I guess my question should be ,what trouble spots to look for, and how does it drive and handle.
I am finishing up a 39 business coupe. I put a Heidts front end under it and a 69 camaro rear axle. ZZ4 with TPI injection and a 700R4. I haven't put a lot of miles on it but it drive nice so far. The frames are already boxed however adding a K-member helps stiffen things up. As far as parts go, there are far less suppliers for Fords. Chevs of the 40s, The filling station, and i and i reproductions come to mind. Over the years, I have gathered names of guys dealing with original parts. I love the look of the 39 and since the one I own was my dads first car, it means even more to me. Let me know what you are looking, I have a small stock of parts and sources. -Dan
Depends, g***er or custom street rod. Mine has a straight axle setup with Camaro disk brakes front, and CE coilover setup Ford 9" in back. Posted using the Full Custom H.A.M.B. App!
I had a '38. Quite similar. Used a M-II front, non-power steering (car is too light for power, IMHO), standard discs. Aspen (Plymouth) rear. Stock springs, sway bars front and rear. This car was a dream to drive. Rode very well, handled quite competently, and was my only car for two years. By all means, drive the car before purchase. It should not ride rough, if it does, someone may have cut coils to get it low (not necessary if built right), as a friend found out on his '37 that was Nova-clipped. Badly. Actually, if built right, should drive like a Camry, but with a trunkload of soul, which is missing from the Camry. Cosmo
It's a custom straight tube axle built by Chris Boccioco (Choke) in northern California. He is now specializing in g***ers. If you decide to go the g***er route let me know and I'll take some pics for you, pretty simple setup. Posted using the Full Custom H.A.M.B. App!
Did you ever find a coupe? I know where one is, for sale, complete. The owner is not much for computers, but it is a great car. reply to me only if serious.
Finished this one (almost) prior to 1968. It became my daily driver. Not a Coupe but the ch***is is the same if you find a beam axle Coupe. Used the original beam axle and added a 55 Chevy rear end, 283 4 bbl. and Power Slide. I was a kid and I loved that Old Sedan..............Jeff
My 37 Chevy has a Ch***is Engineering Mustang II front end . It is the bolt in type. in other words it uses reference points from the frame and frame holes to line it up.(not welded to the frame) Been under the car for 19 yrs, only replacement was a weak P/S rack .
Here is a "How To!!!" from Rod & Custom Archives........................Jeff http://www.rodandcustommagazine.com/techarticles/1205rc_1939_chevy_front_suspension/viewall.html
