Pic Request!!! DRILLED AXLES!!
Discussion in 'The Hokey Ass Message Board' started by usmc50lx, Dec 4, 2010.
  1. usmc50lx
    usmc50lx
    from St.Louis
    Alrighty boys and girls lets see those drilled axles and not your superbell or so-cal drilled pieces please some home ingenuity drilled or slotted axles! Just trying to get ideas for this new axle for this project of mine.:cool: Thanks-Paul
  2. Slag Kustom
    Slag Kustom
    my drilled axle did not hold up to well on the street
  3. Jeeze, I seriously thought this was about redrilling rear axles to a different pattern. (I wanna change my trailer from Ford/Dodge to Chev).
  4. 296 V8
    296 V8
    from Nor~Cal
  5. Weasel
    Weasel
    Mine - original 1950s....
    [​IMG] [​IMG]
  6. hotrod harry
    hotrod harry
    from wisconsin
    this what i did to my axle, not exactly drilled, but alittle different.
    it follows other lightening holes i punched into the rest of the car
      182.5 KB
  7. usmc50lx
    usmc50lx
    from St.Louis
    thanks Harry thats exactly what I wanted to see something a lil different I think i'm gonna alternate hiole sizes on the bridgeport today with it, pics when I'm done! I'll weigh it before and after too!
  8. tommy
    tommy
    No pictures but I did my axle back in 1980 before it became popular again. Super Bells were the hot lick. I found and old dropped axle and had a buddy drill it for me.
    1/2" 3/4" 1" 3/4" 1/2" 3/4" 1" 3/4" 1/2" 3/4" etc .etc.
  9. Idaho/Dave
    Idaho/Dave
    from Idaho
    Here is one that was under my 34 5 window, 19 3/4" holes + one each end for the shocks. 5 window was said to be a early drag car (New York area)in the 60s? Dave
  10. thunderbirdesq
    thunderbirdesq
    My roadster has an old dropped/drilled/chromed one under it.
  11. brady1929
    brady1929
    that roadster is beautiful
  12. fab32
    fab32
    X2:cool:
    Frank
  13. designs that work
    designs that work
    Drilled at home on a Harbor Freight Drill Press. Made a jig, vertical tubing guide with a flat plate welded at a 90 degree angle, plate ground to axel inner width. Vise grip plate to axel, run the drill bit through the tube. Used one hole to mount panhard bar.
    Good Luck Duane
  14. HotRodBen1987
    HotRodBen1987
    Nothin fancy, but does have holes now
    Seventeen 1" holes
  15. gasserrod
    gasserrod
    from maryland
    55 f100
  16. FORDY 6
    FORDY 6
    Not a good pic...the original dropped & drilled axle on my A coupe.
  17. Bull
    Bull
    My A Roadster:
  18. titus
    titus
    slots and holes
  19. 64 DODGE 440
    64 DODGE 440
    from so cal
    Here's ours for our HA/GR project...21 one inch holes in a 40s Lincoln I beam.
    On the wall when it was first done:
    From the front showing the spring mount and basic layout for the hairpins as under construction:
    As it looked when first a rolling ch***is:
    And one last one...on the seat, we still have a way to go: :D
    Build thread:
    http://www.jalopyjournal.com/forum/showthread.php?t=189651
  20. S.F.
    S.F.
    WHOA!!!! i just freeked out alittle...
  21. metal man
    metal man
    This one is under my tub project now.20 holes 3/4" dia.
  22. elmitcheristo
    elmitcheristo
    A swap meet find from today. Not going to be used for anything but a wall hanger. But it is drilled, dropped, and slotted.
  23. JimSibley
    JimSibley
    Here's mine. Drilled
    40
    Axle, narrowed and dropped to
  24. Just Gary
    Just Gary
    My '34 axle... Jacks & Deuces (Fuller's frames & axles) dropped it then I drilled and peaked it.
