1932 3w Build Thread / “Freshening Up”
Discussion in 'Traditional Hot Rods' started by CTaulbert, Apr 28, 2014.
  1. Pure Hot Rod stance
  2. flatheadpete
    flatheadpete
    from Burton, MI
    Webb Automotive hits another one outta the park. Can't wait to see it.
  3. Outback
    Outback
    from NE Vic
    Wow, that's looking great! looking forward to further updates!
  4. mad mikey
    mad mikey
    AWSOME! Pure hotrod!
  5. onekoolkat1950
    onekoolkat1950
    Love the way the rear tires are stuffed in the fenders, looks perfect.
  6. PRIMER STUDIO
    PRIMER STUDIO
    from Butte,MT
    Looking fantastic!
  7. Malcolm
    Malcolm
    from Nebraska
    Great stuff, Cory... I always enjoy following along on your builds - great selection of parts, always nice work and tastefully done. Perfect!
    Malcolm
  8. T&A Flathead
    T&A Flathead
    Looks great Cory.
  9. UNCLECHET
    UNCLECHET
    Damn you guys build some nice cars! Love this one too!
  10. Muttley
    Muttley
  11. 29bowtie
    29bowtie
    Just absolutely perfect! WOW!
  12. 333tinman
    333tinman
    from MASS.
    Cory, nice car !!! Do those front brakes bolt up to 32 spindles or was there some work that had to be done? Karl
  13. opunui
    opunui
    from Honolulu
    Love this build..
  14. 3wLarry
    3wLarry
    from Owasso, Ok
    2 weeks...any updates?
    kidcampbell71 likes this.
  15. PurdueSD
    PurdueSD
    Holy ****! This is nice!
    ps. a hot rod deuce 3w and a volt in the driveway? Sacrilege!
  16. CTaulbert
    CTaulbert
    from Detroit
    Yes - the brakes do bolt up to '32-34 spindles, and do not require any spacer ring to center the backing plate. You still need the spindle spacer to properly locate the inner wheel bearing due to the longer snout. Everything was from Early V8 Garage, and of superb quality.
    Yeah....well....I forgot to mention that we were in the middle of some house remodeling and that went full steam. Fortunately, it's wrapping up this weekend so I'll get back to the car (and updates) next week.
    The extremes of both worlds.....
  17. alfin32
    alfin32
    from Essex, Ma.
    Would expect no less Cory, fantastic!
  18. Anticipating the ****on Up-date on this one.
  19. 3wLarry
    3wLarry
    from Owasso, Ok
    Wonder if the paints dry in his bathroom yet? ;)
    kidcampbell71 and Mr48chev like this.
  20. CTaulbert
    CTaulbert
    from Detroit
    ok......ok.....
    I'm back to working on the car. Dan finished up the exhaust, which turned out to be quite a lot of work making a set of headers (specifically the driver's side). They should be on the car tomorrow.
    Meanwhile, I've started on the wiring. I made a small panel that mounts using a couple of the firewall mat fasteners. On it are a few relays for the Columbia vacuum controller and ignition, along with a small fuse block to protect some circuits. It mounts up pretty high, so it should be difficult to see when the car is down on the ground. I also got the upper radiator hoses finished up, and clamped everything with some NOS Firestone thumbscrew clamps. I also modified a Stromberg fuel line for a Offenhauser dual intake (has the same carb spacing) to work on this Navarro dual intake. I did have to make a small rubber section to meet the fuel pump, which is also clamped with some NOS Wittek thumbscrew clamps.
    I installed the steering box tonight, which is a '37 Nash box that Neal Jennings built. Dan put one of Neal's '37 Hudson boxes in his tudor, and really liked it. I even picked up one for my future 5w project too. Anyway, it's a perfect piece and directly fits in place of the '32 box.
    As far a electrical stuff, I just need to route the harnesses to the lights, coil, generator, etc....so it's not too far off. I'm hoping to get the front sheet metal back on the car by the end of the weekend.
  21. CTaulbert
    CTaulbert
    from Detroit
    paging @3wLarry........
    We got some more progress done on the car over the weekend. Dan finished up the stainless tube headers that he built for the car. Getting the tubes to clear everything on the driver's side of the engine bay is no small feat. I also continued on the wiring, routing the headlight wires and soldering on the terminals for the connectors.
    We were in a dilemma with the running boards - the p***enger side was original and in decent shape, but the driver's side was recovered at some point, and it was separating. Dan's tudor was in need of a p***enger board to make a good pair on the car, so we decided to get some new Drake boards for the 3w. According to Dave Rehor, they're the most accurate boards out there. We hung those today, along with the front fenders.
    The fuel tank had varnished gas in it, along with a look of sludgy looking stuff. We drained the tank, and soaked it for a couple days with vinegar. It got rid of most of the sludge, but we did a couple day soak with E85, which got the rest of it out. The tank still had some rust scale inside so after researching on the Fordbarn about electrolysis cleaning, I took a shot at it. It turned out great, and looked brand new inside. We swished around a little kerosine to protect the steel and drained out the left over. I sat the tank in place and hooked up the fuel line and hydrostatic line, but I still need to put the bolts in.
    Outback likes this.
  22. TexasSpeed
    TexasSpeed
    from Texas
  23. 3wLarry
    3wLarry
    from Owasso, Ok
    Thanks for the page Cory...:)
  24. Hitchhiker
    Hitchhiker
    Looking amazing!
  25. n.z.rodder
    n.z.rodder
    WOW, simply perfect!
    Scotty.
  26. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Man I love how clean your work around this old car is. Everything is coming together really nicely. I admittedly did not like the divco's out back but I am learning to deal with them as time goes one (not that anyone cares about my opinion nor is worth anything haha) The rest of the car is a dream come true for me. Early Ford with old black paint, Detailed Flathead, Lowered just right? Yes please!
    Hitchhiker likes this.
  27. alchemy
    alchemy
    Will you be bringing it to Back to the Fifties, or will we need to wait for the Des Moines Goodguys?
  28. CTaulbert
    CTaulbert
    from Detroit
    We're shooting for Columbus with it, and that should leave plenty of time to shake out any issues to make sure it's road worthy.
  29. Cody Walls
    Cody Walls
    I cant wait to see this thing in person
