Technical lowered 51 Pontiac steering issue
Discussion in 'Traditional Customs' started by TonyVoltron, Jun 16, 2014.
  1. TonyVoltron
    TonyVoltron
    I just put on the fat man drop up rights (3 inch). Everything was machined and ***embled well. Now I have the wheels pigeon toed and steering tie rods are now hitting the center bar. What's the best solution for this? Is there a kit? Thanks in advance.
  2. Canada Jeff
    Canada Jeff
    Did you use the dropped steering arms too, or the originals? Got any pictures?
  3. "old injun"
    "old injun"
    from Lansing IL
    fatman told you need to heat the steering arms..
  4. HOOLIGAN350
    HOOLIGAN350
    I have the same spindles on my 51 Pontiac, like old injun said, you need to heat the two steering arms, mounted to the spindles and let them cool very slowly. I left mine in sand to cool, they're fine and I've jumped a curb or two since then.
  5. TommyGator
    TommyGator
    I am looking for the best price option to lower my 1950 Pontiac Streamliner. I plan to keep as much stock suspension as possible but would like 4 inches lower if possible. I have seen several drop spindle options on line and springs that are supposed to drop it too. What do you guys suggest to get the most drop for the money with minimal geometry issues? Do you guys recommend the Fatman spindles or is there a less expensive alternative.?
  6. TonyVoltron
    TonyVoltron
  7. TonyVoltron
    TonyVoltron
    I got the kit from Jamco
  8. "old injun"
    "old injun"
    from Lansing IL
    I purchased pair 2" front springs from [ ispo's springs ] I may have name misspelled,cost was around $100.
  9. TonyVoltron
    TonyVoltron
    Bent the steering arms today
  10. BORRACHO13
    BORRACHO13
    from Menifee CA
    i see no no pics o_O
  11. TonyVoltron
    TonyVoltron
    These are the Fat Man drop uprights
  12. TonyVoltron
    TonyVoltron
    So we took a measurement to see what would take the pigeon toe away from the car. We divided it in half and used that length for each side. We then heated each side and bet the rod to the desired length , slowly and carefully 20140621_111854.jpg
  13. TonyVoltron
    TonyVoltron
    Before the rods were bent, they hit on each side and would not move because of the drop. I am also learning as I go here. I am lucky to have friends that are into the same things with knowledge and are not ****s
    jsu1313 likes this.
  14. Toast
    Toast
    from Jenks, OK
    I just installed the Fatman drop uprights on my 55 and don't remember needing to bend the arms that far. Have you tried to get it rolling again since you bent them?
  15. TonyVoltron
    TonyVoltron
    they had a slight bent stock. My buddy has a 53 Chieftain where I transplanted my old motor. His steering arms are different as well.
  16. TonyVoltron
    TonyVoltron
  17. freiertpc
    freiertpc
    if you need more parts i have a 54 hardtop coupe
    sitting around
  18. TonyVoltron
    TonyVoltron
    Cool thanks
  19. J.C. Andersson
    J.C. Andersson
    TonyVoltron, I am also looking for options to get my Poncho closer to the ground, and read some threads on the subject including Fatman uprights. All says "Heat and bend the steering arms". I am afraid that you are bending the wrong arms. It seems like you have bent the tie rods instead of the steering arms. It looks a little strange to me.
    Regards,
    Jan C.
  20. TonyVoltron
    TonyVoltron
    J.C. I literally had no choice. They were touching and would not work unless I increased the bend on them. My buddy owns on a high end muscle car/ hot rod shop and my other buddy is a serious fabricator. If I was doing something wrong they have no problem letting me know.
  21. freiertpc
    freiertpc
    im stepping the frame in my belair but was debating on swaping to the pontiac frame and doing the 58 buick and pontiac upper and lowers with ball joints for discs and theres also room to do a drop pitman/idle arm setup to take those bends out like on a body dropped mini
  22. TonyVoltron
    TonyVoltron
    I can't comment there. I'm sure one of the guys on here has good imput
