Technical 1932 ford V8 coolant outlets
Discussion in 'Traditional Hot Rods' started by blindowl, Jun 17, 2014.
  1. blindowl
    blindowl
    from MASS
    Hey guys I'm looking for a set of repro engine water outlets . These are on 1932 V8 only. I have the engine mounts just need the outlets. It there a company making them ? Please let me know. Thank you
  2. I ***ume you mean inlets where the water enters the block from the radiator.
    Charlie Stephens
  3. $um Fun
    $um Fun
    from Nor Cal
    They are also early '33.
  4. blindowl
    blindowl
    from MASS
    Didn't know they where on 1933 ford. I thought it was a different front cross member. So does anyone repro them or have a set ??
  5. Andy
    Andy
    I have seen cast and sheetmetal versions. I would make a set from sheetmetal if it was me. A set of 33-36 inlets could be cut up to make the cast versions.
  6. $um Fun
    $um Fun
    from Nor Cal
    Only on the early '33 Fords, they had the narrow engine mounts similar to a '32. I cant get his name but there is a member on the forum that had a really nice set. You could find him with a search, he makes the tool to take apart the '32 carb. Might also try posting on Ford Bran.
  7. DICK SPADARO
    DICK SPADARO
    Cast style, In stock PM or call
  8. blindowl
    blindowl
    from MASS
    Thank you to all. I found a set.
