Technical Banjo Axle ID
Discussion in 'Traditional Hot Rods' started by King Callie, Jun 18, 2014.
  1. King Callie
    King Callie
    from Virginia
    I purchased this banjo rear a while back. I was told it was a forty. The axles measure about 32 and 7/8 so according to the tardell book it should be from 35-41 but I can't seem to I'd the housing by the spring perch. Any ideas? I am trying to make sure it is what I want for an AV8 and if not, know what it is so I don't sell again to someone else under false pretenses. Thanks!
  2. dgasbag
    dgasbag
    from Upstate NY
    It appears to be a '41 with sway bar attachment
  3. 48-760
    48-760
    from OH
    Yes it would have to be 41 or after , because of the rear sway bar attachment.
  4. butch27
    butch27
    Every one I've ever bought was said to be a 40.
  5. King Callie
    King Callie
    from Virginia
    Is it either desirable or undesirable because of the sway bar mounts? Any reason you wouldn't use it on a roadster?
