Technical no cotter key hole
Discussion in 'The Hokey Ass Message Board' started by joee, Jun 20, 2014.
  1. Ulu
    Ulu
    from CenCal
    VW's used the split nut with a pinch bolt & it worked fine. It's just heavier and more expensive than a cotter key.
    I've also used the "Micro-Loc" spindle nuts, which is a finer version of the Ford stamped "castle" retainer. I liked them well.
  2. 61 chevy
    61 chevy
    who pays shipping ? I would drill
  3. To edit my first post, I should have added that I had not seen the tang washer on a car but have used them on large trailer axles. They look similar to the one above and do the job, All the cars I have worked on had the cotter pins. I would not be afraid of the washer as long as it was installed as said, before the nut. Be sure to bend the top tab over a flat on the nut.
  4. tfeverfred
    tfeverfred
    Bet you'll call Speedway first, next time.
    gas pumper likes this.
  5. Bearing Burner
    Bearing Burner
    from W. MA
    My speedway spindles had a hole in each. However I had to make 1/4" spacers to tighten up on the
    early GM rotor bearings. Has any else had this problem?
  6. gimpyshotrods
    gimpyshotrods
    What's wrong with using OEM spindles?
  7. we are building hot rods and are mixing and matching parts and at times some modifications are required just use common sense and don't over think the problem just be safe as far as locking tab washers i usually see them used on hollow shafts that something p***es in the center like full floating axles, four wheel drive hubs, harley clutches
  8. ago
    ago
    from pgh. pa.
    Speaking of Micro-loc nuts, anyone have a part # for them to fit early Ford spindles. I like the idea of having a finer adjustment.
    Ago
  9. joee
    joee
    has anyone used Loc***e to hold a spindle nut on /not using cotter key just Loc***e? did it work? anyone have any insight on if it would work or not?thanks
  10. 3banjos
    3banjos
    from NZ
    Dont go there Joee
  11. brokenspoke
    brokenspoke
  12. Muttley
    Muttley
    Sounds like an OlSkooooolRodzzzzzzzzzzz tech article.
  13. it would probably be fine but why the hell would ya, the split pins there for a reason, its a fool proof way of insuring your front hub don't fall off an you don't kill yourself and some other poor ******* sharing the road..
  14. joee
    joee
    no hole in the spindle for cotter key
  15. stimpy
    stimpy
    no hole for a spindle nut then double nut it with a spindle nut cage
    [​IMG] or drill it if you have more than 2 times the diameter hole material left on the spindle fromthe outside of the holes edge and try to use the smallest cotter key possible , because the brakes or the bearings will heat the spindle up enough to soften the lock***e , or you will get lock***e on the race seat or inthe bearing face and then its a pain to get loose unless you put a lot of heat into it .
  16. No, reason is because that nut isn't very tight.
    Get this thought out of your mind, now
  17. joee
    joee
    I'm thinking Loc***e and preload would be a problem......I like others thoughts it get's me thinking. thanks to all
  18. OLDSMAN
    OLDSMAN
    When I was a rod tech for Speedway I ran across these problems from time to time. Yes the spindles are supposed to be drilled for a cotter pin, and in some applications you need a spacer to get the bearings adjusted properly. They will exchange the spindles for good ones. This happens because of cheap Chinese ****, and not enough QC. Speedway has always made good on their mistakes though, just a big inconvience to you
  19. gimpyshotrods
    gimpyshotrods
    Kwalatee kontrol. We leave out the S, for safety.
  20. unkledaddy
    unkledaddy
    School me on how that works.
