Projects 1951 Ford Country Squire, chrome reverse time. Thoughts & Ideas !
Discussion in 'The Hokey Ass Message Board' started by rob-redm, Apr 13, 2014.
  1. 49ratfink
    49ratfink
    never knew those side panels were metal. learn something new every day. someone mentioned Woodies on the Wharf in Santa Cruz, I bet there are twenty five 1949 - 1951 Woodies there every year. by far the most popular cars in the show.
  2. trh351
    trh351
    from Kansas
    I looked up the possible color you are seeking and it looks like Silvertone grey. Here is a picture like your car. What do you think?[​IMG]
  3. rob-redm
    rob-redm
    Starting to re***emble the driver side door..
  4. rob-redm
    rob-redm
    I was wondering if that may be the color... need to get the car into the daylight...Silvertone Grey or Sea Island Green Poly.. The rims have a green tint to them, which we had off to mount tires... Thank you
  5. rob-redm
    rob-redm
    Bruce and I got the driver side door pretty much back together this afternoon... It's one fun jig saw puzzle ... But we are getting there....
  6. rob-redm
    rob-redm
    back at it today....finish up the door... on to the rear quarter wood...
  7. rob-redm
    rob-redm
    driver door done !
  8. rob-redm
    rob-redm
    so moved over to the p***enger side door this evening. Bruce & I got the upper and lower wood frames off the door.
  9. DRUGASM
    DRUGASM
    Looking good Rob.
  10. rob-redm
    rob-redm
    Thank Bro ! Ole Margie is looking good her self ! Miss that wagon...
  11. rob-redm
    rob-redm
    not much to report, dis***embled the door wood frame today..
  12. rob-redm
    rob-redm
    so more varnish on the p***enger upper door wood frame, the left upper quarter wood frame...So it's about 10-11 coats of varnish ... Wet sand...Bruce got the lower glued together... The middle spar and dog leg Bruce made.. After taking the p***enger door apart..I have more work to do on the driver's door.... More screws into the top, middle and lower wood spars... ACE is the place for more wood screws ! LOL We are shooting to have is all back together by the end of this month... Then off for some mechanicals... I won't make Billetproof... Goodguys I hope..
  13. rob-redm
    rob-redm
    I just love taking something apart after its back together... After taking the p***enger side apart.. I realized that I missed about 6 retaining screws on the inside of the door that held the wood frame to the door...Hey it went back together faster the second time !
  14. rob-redm
    rob-redm
    Well, we did some wet sanding on on the varnish on the frames and added another coat... Stripped off the old door weatherstrips and clean off the surfaces...Big bummer The D.C. restoration 49-51 Station Wagon door seal kit was mis-packaged and contained seals for a 2 door sedan kit.... So no door seal kit install....should have p***enger side together very soon...
  15. rob-redm
    rob-redm
    Well been a while since I posted some updates on the ole woodie...So the p***enger side door wood is all varnished and ready to be reinstalled. I did get the upper frame on today... The lower door frame's varnish was still to soft... Will need to install the wood grain metal panels & screw it all down with the wood batting strips. Removed the inner quarter trim panel, and dis***embled the tail gate bracket.. Bruce & I started taking the wood of the upper quarter...Some of the harware ole Henry Ford used is crazy. Getting the upper metal wood guide out require some work...They used a metal wood tack the went through the metal channel and into metal body.. The used these odd metal tacks also to hold the headliner down along the side... Fun ! lower quarter tomorrow...Hope to finish the p***enger door...
  16. plywude
    plywude
    from manteca ca
    Woodies on the Wharf was awesome I was #157 and cars continued to come in after I came in, I think they may have hit the 200 mark. Just like LARS is a must go to WOW for Woodie owners is too.
  17. rob-redm
    rob-redm
    still working on the ole Woodie...I was able to finally finish the p***enger door today...Should be able to start putting the driver quarter back together...need to straighten the upper window guide channel that is tacked in above the rear side window opening. someone was really frustrated trying to remove it 40 years ago.. bent the **** out of it... just glas they are still with the car..
  18. rob-redm
    rob-redm
    so we should be able to start getting the driver side rear quarter back together and gl*** back in.... we missed our Billetproof date.. oh well ... Maybe Goodguys in Puyallup for it... These cars are alot of work I'm finding out .. But it's worth it in the end... I have a Woodie which I thought would never happen... Just get keeping at it...
  19. rob-redm
    rob-redm
    taking a break from the car this weekend..
  20. rob-redm
    rob-redm
    on like Donkey Kong on Tuesday.. we have the lower driver quarter on now... Now for the upper frame and install gl***...
  21. rob-redm
    rob-redm
    Hoping to have gl*** in soon
  22. rob-redm
    rob-redm
    ok so all the wood is done and bolted on the car... Saturday need to install some of the smaller retaining screw on the inside quarters upper and lower wood frames... Then windlaces,fuzzies and gl***... then install the garnish moldings, and interior trim panels...
  23. rob-redm
    rob-redm
    p***enger gl*** is in... That was a tough job..
  24. 51 BIRD
    51 BIRD
    That is sooo cool! I'd use the stock hubcaps on those chrome reverse rims and call it a day. Congrats Rob!
  25. rockable
    rockable
    sweet! I'm jealous!
  26. HOTRODPRIMER
    HOTRODPRIMER
    Man,the woody is really looking good! HRP
  27. rob-redm
    rob-redm
    So got the driver inside garnish molding & lower interior trim panel installed. Also the upper "B " & "C" pillar trims panels in. The quater gl*** is all installed on the driver side... Tuesday re-install the inner panels..Getting there
  28. rob-redm
    rob-redm
    Ok ! so the wood is all done and installed, gl*** is all installed, the interior garnish and lower trim panel installed... YEAH ! now off for some mechanicals....Just may make GG hopefully... Bruce really busted his **** stripping the wood of it yellow paint.. sanding it , restaining and varnish... Some late nights for sure.. I am very thankful for all his hard work, and it was fun helping putting everything back together... I learned alot on how these cars were ***embled.. my hats off to the Ford employees who put them together over 60 years ago.. They are alot of work.. Mr. Patjens (RIP). He never threw anything away.. everything he removed was in the car... Plans are to take his three boys and widow for a spin around Tacoma when its road worthy...after 40 years it will be hitting the roads in Tacoma once again ..Bruce's ole Model Woodie had to share..
  29. rob-redm
    rob-redm
    So fixed the taillight(still alot mechanical things to do ) But took it for a short drive to the store and back, drove like a dream.. Now coming home to T-town...
  30. tevintage
    tevintage
    Looks great Rob. Very natural. Will make a lot of folks smile! Enjoy, thanks for the post. T
