Projects Plan II - 62 Chevy II Drag Car
Discussion in 'The Hokey Ass Message Board' started by squirrel, Dec 27, 2013.
  1. squirrel
    More video. Ran it at the strip in Tucson last night. Not quite the right wheels/tires...I'm working on that. But it ran 11.01 first run ever, and 10.58 second run. And Tucson is usually at least half a second slower than other strips I've raced at (3000 ft elevation and it's hot)
    another view, from my brother's phone
    It was a fun night, my wife went with me, my brother and son showed up to watch and help.
    I have a few problems I need to fix, like the oil spattering all over the windshield, and the tendency to drop oil pressure at 120 mph. But I'll get it figured out.
    winr, Desoto291Hemi, 1Nimrod and 2 others like this.
  2. jimmy1931
    jimmy1931
    Jim, thanks for posting vid. Awesome job on the build. Fantastic results for first time out. I'll bet you are still smiling!
    1Nimrod and els like this.
  3. Dan Hay
    Dan Hay
    Great videos!
    1Nimrod, els and Finn Jensen like this.
  4. hoop
    hoop
    Wow ,Down the track straight as an arrow.You have done an amazing job on that car.
  5. Babyearl
    Babyearl
    I would say,,You did good,, I'll bet you are still smiling.
  6. swade41
    swade41
    from Buffalo,NY
    Whoa mid 10's, drag week is going to be interesting..ha ha congrats man !
    els likes this.
  7. malibumonte78
    malibumonte78
    Awesome looking run. Keep us informed on the oil splattering issue. I have been trying different evacuation setups on my high compression big block race car without any luck.
  8. 69fury
    69fury
    from Topeka
    Car's workin, that's for sure! Thanks for the ride!
  9. squirrel
    thanks! It was a fun ride, I am still smiling
    I'm working on the hood now. I think half of the stuff on the windshield was coolant, the other side got some oil. I may put a header evac setup on one side, plumbed to the fuel pump block off plate. I'm not sure yet. At least with the hood on the car, most of the **** will not get on the windshield ;)
  10. 61dailyf100
    61dailyf100
    Too cool ! Thanks for posting the ride along, looks like the wheelie bars held well !
  11. Hyway Hauler
    Hyway Hauler
    This car is awesome!
  12. captmullette
    captmullette
    nice car.......tires and you are haulin ***
    els likes this.
  13. belair
    belair
    Congrats. A cool car done in record time.
  14. squirrel
    Thanks!
    Working on the hood. More fun bodywork on s**** metal. At least, this is the last part.
    Desoto291Hemi, 1Nimrod and els like this.
  15. Jay.S
    Jay.S
    What are you going to use to mount the hood? Pins all around or make something to mount the stock hinges too?
  16. squirrel
    I'm going to try to make my own simple hinges, as far back and high up as I can. We'll see how it works out. Stock hinges mounted on the inner fenders, there are no inner fenders. And I have to be able to open the hood by myself, which is possible but a real pain if it only has pins holding it on.
  17. enloe
    enloe
    from east , tn.
    WHAT ABOUT MAKING IT WHERE IT HINGES FOWARD. THAT MIGHT MAKE IT EASIER TO WORK ON?
  18. squirrel
    Hinging forward won't work, as the hood would hit the rear carb.
  19. tpw35
    tpw35
    Squirrel, what is the differance in the weight of the two cars?
    els likes this.
  20. squirrel
    Right around a thousand pounds.
  21. squirrel
    Bottom of the hood, showing the bracing. It stiffened up even more after I tacked all the tubing together underneath. I started working on the hinges. Pretty simple. One pin is welded to the hood, the other is a bolt that I can remove to take off the hood. I've never seen one done like this, I hope it works.
  22. Jay.S
    Jay.S
    Curious to see how you mount this to the fender. You just going to beef up that one inch drop on the fender? Or make some sort of entire different mounting point?
    els likes this.
  23. George G
    George G
    Nice
    els likes this.
  24. squirrel
    I did some play fitting of the hood yesterday, the hinge won't work as I had envisioned, because I didn't realize how high the center part of the hood is relative to the hinge pins--it moves back into the cowl, instead of up. So...I'm planning on making the hinge point be above the hood. It'll look kind of funky having exposed hinges, but I think it will work ok.
  25. aerorocket
    aerorocket
    from N.E. P.A.
    Love your car, you have done more in 6 months than I have in 6 years. Looks like it worked perfect in the videos. Do you think it might e.t. a little quicker with a little more converter? Nice job good luck at drag week.
    els likes this.
  26. bobss396
    bobss396
    I like the idea of 4 hood pins myself. I always did that on my stock cars and mounted 2 cheap Ace Hardware simple door handles so I could take it off myself in the pits.
    els and MoonLoon like this.
  27. squirrel
    It sure would. That's on the list of things to do if I want to go quicker, but give up some period correctness. The converter in it now is from the 60s.
  28. lippy
    lippy
    from Ks
    Great job Jim !! Sounded great.
  29. Jim, if you've still got a little time and want hidden hinges that will work with the bird catcher look into fabbing a pair of parallelogram hinges. I've built a few sets and they let the hinged panel move almost parallel to the surface it closes against for quite a distance. Start with cardboard and screws to mock up the geometry. It's really not as hard as it looks. Staggering the link lengths allow the open position to be any angle you want. Same principle as a stock hinge with infinite options.
  30. squirrel
    That's a great idea! but I'm thinking the ugly exposed hinges will be fine for this car. I'll definitely think about it, though.
